slimjim Posted July 27, 2011 Share Posted July 27, 2011 Where is the best place for me to track the cables for an ICE install? Presuming the power is best off going down the empty white channel by the side of the passengers sill? Then for RCS and return to the speakers... Can I use the central section or am I best going down the other (cramped) side? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 27, 2011 Share Posted July 27, 2011 Presuming the power is best off going down the empty white channel by the side of the passengers sill? Then for RCS and return to the speakers... Can I use the central section or am I best going down the other (cramped) side? Yes and centre armrest section Theres a grommet by the battery that will lead the power cable down to the passenger footwell. Run it through the grommet, down and along the empty channel and up to the cubby Quote Link to comment Share on other sites More sharing options...
slimjim Posted July 27, 2011 Author Share Posted July 27, 2011 Sweeet... Cheers Chris! Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 27, 2011 Share Posted July 27, 2011 Have fun getting through the grommet Quote Link to comment Share on other sites More sharing options...
slimjim Posted July 27, 2011 Author Share Posted July 27, 2011 Easy as pie Just used the good old "wire coat hanger" trick And I THOUGHT this was going to be a TRICKY install Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 27, 2011 Share Posted July 27, 2011 You had a better time of it than me, I could hardly get into the grommet Rest of the install is dead easy though you're right. Quote Link to comment Share on other sites More sharing options...
slimjim Posted July 27, 2011 Author Share Posted July 27, 2011 You had a better time of it than me, I could hardly get into the grommet Rest of the install is dead easy though you're right. Must just be luck I guess! Quote Link to comment Share on other sites More sharing options...
