Strange noise from front
mrobinson2
The Zed has developed a strange noise that seems to be coming from the front passenger side wheel. The noise is best described as the same noise you get when your exhaust's heat shield is loose if that makes sense. It only makes this noise when the car is on at least half lock when turning left.
Anyone got any ideas what it might be?
Its a very disconcerting noise to have coming from that area.
Have a look at the rotor dirt shields or inner arch liners:thumbs:
Alex is right. Ive had the same problem on other cars and it tends to be the shield which goes behind the brake disc. Sometimes it can get bent a bit and catch on the brake disc. Usually only happens if your turning in one direction. I just bent it back from the disc slightly and it fixed it.
