ZedMeister Posted July 22, 2011 Share Posted July 22, 2011 Bought a hydraulic jack today plus two axle stands to make work on the Zed easier, the jack points seem very flimsy though for the axle stands? How does everyone else do it? I checked out this thread - viewtopic.php?f=10&t=41903&hilit=jack+points Although the guy Ian's photo doesn't work. Quote Link to comment Share on other sites More sharing options...
Husky Posted July 22, 2011 Share Posted July 22, 2011 use the central jacking point at the rear, it's on the diff. Then pop some axle stands under the sides Quote Link to comment Share on other sites More sharing options...
Ian Posted July 22, 2011 Share Posted July 22, 2011 Quote Link to comment Share on other sites More sharing options...
DoubleDeuce1973 Posted July 22, 2011 Share Posted July 22, 2011 Is the jacking point on the diff the cylinder shaped thing that sticks out or is it just any point on the diff? Quote Link to comment Share on other sites More sharing options...
ZedMeister Posted July 22, 2011 Author Share Posted July 22, 2011 use the central jacking point at the rear, it's on the diff. Then pop some axle stands under the sides The sides were my concern, thin flimsy looking stuff, no? Where the stock 350 jack is meant to sit? Quote Link to comment Share on other sites More sharing options...
Husky Posted July 22, 2011 Share Posted July 22, 2011 Never had a problem with them myself, my axle stands are shaped to fit that contour though. Quote Link to comment Share on other sites More sharing options...
ZedMeister Posted July 22, 2011 Author Share Posted July 22, 2011 Never had a problem with them myself, my axle stands are shaped to fit that contour though. I'll post some pictures tomorrow hopefully, show ya'll what I'm dealing with Appreciate the reply though bro. Quote Link to comment Share on other sites More sharing options...
Husky Posted July 22, 2011 Share Posted July 22, 2011 no worries Quote Link to comment Share on other sites More sharing options...
Husky Posted July 22, 2011 Share Posted July 22, 2011 Is the jacking point on the diff the cylinder shaped thing that sticks out or is it just any point on the diff? ricey shows you here viewtopic.php?f=35&t=50937&hilit=replacement+guide Quote Link to comment Share on other sites More sharing options...
DoubleDeuce1973 Posted July 22, 2011 Share Posted July 22, 2011 Thanks Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted July 23, 2011 Share Posted July 23, 2011 Jack it up using the Garage Jacking points as shown on the diagram above, if you can't reach them with your Jack drive onto some bricks or wood first. If your gonna put the axle stands on the 'safety stand' points (where the scissor jack goes) don't put them directly onto the soft sill seam that you are speaking of because it will bend ! You need to put something on the seam to protect it that is the same shape as the top of the scissor jack ie. something with a groove in it. I use blocks of wood with a groove cut in them and put the Axle stand on them. If you could get a hard rubber or plastic block that would be ideal. My mate used a hockey puck and that works great too. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 24, 2011 Share Posted July 24, 2011 Take an ice hockey puck (off ebay) and cut a groove in it Dont put a flat jack platform against the seams, it has to be supported either side like the standard jack shape Quote Link to comment Share on other sites More sharing options...
