bubbagross Posted July 20, 2011 Share Posted July 20, 2011 Hi Guys, has anyone fitted a reverse camera to their 370z yet ? I have premium connect Sat nav with the HDD, so am curious to know what is involved, have searched the forum but can't find anything ? Many thanks Bubba Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 20, 2011 Share Posted July 20, 2011 Bit of info here - viewtopic.php?f=103&t=43182 You need to sign up to http://www.the370z.com and search out Brian (user: bdl99). He does the wiring harness and has instructions on how to install it. Needless to say its not difficult and very worth while - if a little expensive on the face of it (it does use Nissan connectors and is completely reversable if needs be, no cutting or soldering of the car wiring) Quote Link to comment Share on other sites More sharing options...
Cragus Posted July 20, 2011 Share Posted July 20, 2011 Sounds like a winner Quote Link to comment Share on other sites More sharing options...
bubbagross Posted August 3, 2011 Author Share Posted August 3, 2011 ordered camera from ebay and cable from Brian in the US, all arrived today, so will fit over the weekend .... Tested the camera in the AV input in the cubby and all works sweet Quote Link to comment Share on other sites More sharing options...
andrew0401 Posted September 14, 2011 Share Posted September 14, 2011 Has anyone managed to install the camera in a roadster? I have a G34 roadster, followed the instructions andit all installed really easily until I came to the final connection between the cabin and the trunk. No obvious holes (only grommet is in the floor of the trunk) to try and fish a cable through and realising that the roof is in the way. Any clues greatly apprciated. Andrew Quote Link to comment Share on other sites More sharing options...
rogerxp Posted September 14, 2011 Share Posted September 14, 2011 Good point about the Roadster; would be interested to hear of any suggestions (bar drilling a hole ). As a matter of interest (and to save me reading through everything again ) how much does all this come to including shipping??? Quote Link to comment Share on other sites More sharing options...
geoff-r Posted September 15, 2011 Share Posted September 15, 2011 Out of interest why do you guys want reverse cameras? Is it simply for parking? Quote Link to comment Share on other sites More sharing options...
bakseedaa Posted September 16, 2011 Share Posted September 16, 2011 Out of interest why do you guys want reverse cameras? Is it simply for parking? I got mine from play.com Quote Link to comment Share on other sites More sharing options...
Craig782 Posted October 2, 2011 Share Posted October 2, 2011 Fitted mine to roadster today Strip out the boot trim / carpet there is a hole next to a loom entering by the speaker, this will then run under the lining in the roof area. Take off the trim panel next to the door with the seatbelt (14mm bolt for the seatbelt rest is just trim clips) You can easily fish it through from the hole in the boot area through to the area in the cab that will allow the wire to run under the roof liner. (When i was figuring all this out i paused the roof half way through for a couple minutes which should cause no issues but other cars i have worked with need a reset when you do this, make sure to continue the cycle if your putting it down when you pause make sure you continue to put it down after your done .... ) Hope it helps All works a treat Quote Link to comment Share on other sites More sharing options...
