Mears5 Posted July 18, 2011 Share Posted July 18, 2011 had a service on saturday went to work today and on the way home the engine light came flashed on now there is a chugging sort of noise when the car is running with a kind or clunking or metallic rattle when the clutch is in the raised position i.e. not pressed down any ideas? Quote Link to comment Share on other sites More sharing options...
Zugara Posted July 18, 2011 Share Posted July 18, 2011 take it back to the dealer who serviced it Quote Link to comment Share on other sites More sharing options...
Mears5 Posted July 18, 2011 Author Share Posted July 18, 2011 yeah thats the plan just wondered if there is anything to make the drive back a bit easier on the car do the 350z's have a limp mode? Quote Link to comment Share on other sites More sharing options...
Zugara Posted July 18, 2011 Share Posted July 18, 2011 You could always get the code, then do the ecu reset.... Noise could be the thrust bearing, a know noise maker... Chugging, spark plug loose/.....what service did you have? Have you opened bonnet and had a look to see if anything is obviously wrong. Oil cap left off? clutching here really mate Quote Link to comment Share on other sites More sharing options...
Mears5 Posted July 18, 2011 Author Share Posted July 18, 2011 yeah opened the bonnet and had a look, nothing noticeable had a p3 service with spark plug change was suggested it could be a plug iv checked all the obvious, will give the code a go and see cheers for the help though mate it is greatly appreciated Quote Link to comment Share on other sites More sharing options...
EH 370z Posted July 18, 2011 Share Posted July 18, 2011 Call the garage first thing in the morning and tell them about your difficulties. Then get the car to them ASAP. If they are worth their salt they will be as keen to the car back as you Good luck Quote Link to comment Share on other sites More sharing options...
Dom187 Posted July 18, 2011 Share Posted July 18, 2011 Just a guess.... All the spark plug leads been put on in the right plug? Or is there a loose connection... Quote Link to comment Share on other sites More sharing options...
Mears5 Posted July 18, 2011 Author Share Posted July 18, 2011 yeah cheers guys its the sensible thing to do. my car is a point of pride to me i guess you could say, so guess i was just panicking a bit. cheers though fellas Quote Link to comment Share on other sites More sharing options...
Ebized Posted July 18, 2011 Share Posted July 18, 2011 yeah opened the bonnet and had a look, nothing noticeable had a p3 service with spark plug change was suggested it could be a plug iv checked all the obvious, will give the code a go and see cheers for the help though mate it is greatly appreciated Easy mistake - as Wasso found out on the last Wales weekend. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 19, 2011 Share Posted July 19, 2011 yeah opened the bonnet and had a look, nothing noticeable had a p3 service with spark plug change was suggested it could be a plug iv checked all the obvious, will give the code a go and see cheers for the help though mate it is greatly appreciated Easy mistake - as Wasso found out on the last Wales weekend. if it was leads to spark plugs then you would of noticed that immediately after collecting the car from service Quote Link to comment Share on other sites More sharing options...
