Has my Z developed the "Clicky Axle Problem"?
djrm
Sounds like it dude, sorry. Mine has it as well but only when going in reverse. I need to fix it but can't afford any medicine right now :blush:
Apparently the click is quite often from only one side. Try listening with only one window open and then the other open to see which side it is coming from. That way you only need to change one.
Ahh I thought so... Bad times...
I will check that when I drive it tonight. Is it an urgent thing that needs to be fixed otherwise will cause major problems or just a glitch that you can live with?
Thanks
Ryan
Thanks
Ryan
Mine has been at it for some time, but I dont really fancy changing the CV Boots which will cost....
There is a temporarily fix to grease them and that should sort it out for a while.
On that matter, does anyone know what sort of grease they need?
