andlid Posted July 27, 2011 Share Posted July 27, 2011 Now take them out on track and get back to us Quote Link to comment Share on other sites More sharing options...
kano Posted July 28, 2011 Share Posted July 28, 2011 Here's what Yellowstuff pads did to by EBC Ultimax discs after about 17000 miles.. Quote Link to comment Share on other sites More sharing options...
was8v Posted July 29, 2011 Share Posted July 29, 2011 Here's what Yellowstuff pads did to by EBC Ultimax discs after about 17000 miles.. were the discs new at the same time? Have you measured the thickness? IIRC they are 30mm new, and wear limit is 28mm. Quote Link to comment Share on other sites More sharing options...
Karlp Posted July 29, 2011 Share Posted July 29, 2011 I'm after som non brembo front drilled and groove discs, can anyone recommend some?? Quote Link to comment Share on other sites More sharing options...
kano Posted July 31, 2011 Share Posted July 31, 2011 Here's what Yellowstuff pads did to by EBC Ultimax discs after about 17000 miles.. were the discs new at the same time? Have you measured the thickness? IIRC they are 30mm new, and wear limit is 28mm. Thats the same disc, one pic the inside surface, the other pic is the outside surface. Both are worn, the inside surface very badly! Quote Link to comment Share on other sites More sharing options...
andlid Posted August 1, 2011 Share Posted August 1, 2011 My guess is that the inside gets warmer first thus making the pads hit they're needed heat to be the best braking thus giving a higher friction and wearing down the disc quicker from the inside. Not sure that's wrong or per design though. Looks like your disc overheated with the cracking in them. Better discs that can take the heat would be needed with them pads. I'm still trying to master a brake duct setup to save the pads and the discs... Quote Link to comment Share on other sites More sharing options...
James B Posted August 1, 2011 Share Posted August 1, 2011 Here's what Yellowstuff pads did to by EBC Ultimax discs after about 17000 miles.. were the discs new at the same time? Have you measured the thickness? IIRC they are 30mm new, and wear limit is 28mm. Thats the same disc, one pic the inside surface, the other pic is the outside surface. Both are worn, the inside surface very badly! I've had the same all EBC setup and it's been a nightmare. By all accounts it's more the poor quality of the discs over the pads, although I don't think you can rely on any EBC product. 'It's cheap @*!#' seems to be the consensus of anyone that's used it. Quote Link to comment Share on other sites More sharing options...
andlid Posted August 1, 2011 Share Posted August 1, 2011 Ebc is a bit strange imo, some people rate them and some don't. In the braking world my opinion is that you get what you pay for, think heat is the biggest culprit if you got decent pads and discs... I wish someone could fab up a nice set of proper race ducts so I can just buy them and fit them and be done with it Quote Link to comment Share on other sites More sharing options...
