Sarnie Posted December 8, 2006 Share Posted December 8, 2006 Calling all you tech geeks We have Sky + in our living room. We have a standard digi box in our bedroom. The Mrs would like a Sky + box upstairs. Been looking at some on eBay and it seems simple enough? Can I just buy a new Sky + box to replace the digibox? Can I use the card in the digibox in the sky + box? Any other possible problems? Cheers The Stig Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 8, 2006 Share Posted December 8, 2006 You can use the card but you will have to phone sky up to give them the new serial number of your new sky + box, they only work with the matched receiver. Changing boxs i am not sure about as i thought that sky + boxs worked with 2 cables from the LNB. Quote Link to comment Share on other sites More sharing options...
AndyC Posted December 8, 2006 Share Posted December 8, 2006 Changing boxs i am not sure about as i thought that sky + boxs worked with 2 cables from the LNB. Confirmed, you need 2 feeds from the LNB. I have a similar problem - communal feed from the satellite on the building (flats) so only 1 feed meaning I can't have sky+ but I believe that can now be overcome. Need a satellite engineer to run you another feed mate Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 Whats LNB? Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 9, 2006 Share Posted December 9, 2006 Low Noise Block but for you sarnie the bit that looks back at the dish with the cables connected to it. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 Low Noise Block but for you sarnie the bit that looks back at the dish with the cables connected to it. So can it be done or not? Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 9, 2006 Share Posted December 9, 2006 Yes i think so with a 4 output LNB Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 With something like this? http://cgi.ebay.co.uk/BRAND-NEW-QUAD-LN ... dZViewItem Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 9, 2006 Share Posted December 9, 2006 http://www.satellitesuperstore.com/skylnb.htm 0.2dB Titanium Quad LNB with Sky mini dish fitting. The adapter on the left means this LNB will fit all types of mini dish. These LNBs are very low noise and offer a good upgrade compared to a standard Sky Mini dish LNB. The adapter fits either type of Sky Mini dish boom arm. This LNB is ideal for use with a Sky Plus or Sky HD receiver and either a standard receiver or a second Sky plus receiver. For UK delivery, choose the £3.95 standard delivery option or the £7.50 priority option Delivery to S IRELAND is £10. Choose the £10 option. Order Code SKYTIT4 £42 Try here Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 9, 2006 Share Posted December 9, 2006 That is a very good item as it as a very low db rating, the lower this number the better the picture you will have Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 Ok. So logistically how do you go about fitting this? I'm assuming you have to clamber up a ladder to the mini dish Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 9, 2006 Share Posted December 9, 2006 Yes just unscrew old lnb and replace with new one, then you will have to run 2 more sat cables to your new box , you will need 4 f connectors and some proper sat cable for this Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 Yes just unscrew old lnb and replace with new one, then you will have to run 2 more sat cables to your new box , you will need 4 f connectors and some proper sat cable for this Stupid Question 2,876,345: What is an f connector? Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 9, 2006 Share Posted December 9, 2006 A connector that goes on the end of the cable to the lnb and on the other end that connects to your sky box. Very easy to fit Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 A connector that goes on the end of the cable to the lnb and on the other end that connects to your sky box. Very easy to fit Not for an electrical/mechanical numpty like me Quote Link to comment Share on other sites More sharing options...
lomoto Posted December 9, 2006 Share Posted December 9, 2006 A connector that goes on the end of the cable to the lnb and on the other end that connects to your sky box. Very easy to fit Not for an electrical/mechanical numpty like me get a man who can in mate, be cheaper in the long run Quote Link to comment Share on other sites More sharing options...
Sarnie Posted December 9, 2006 Author Share Posted December 9, 2006 A connector that goes on the end of the cable to the lnb and on the other end that connects to your sky box. Very easy to fit Not for an electrical/mechanical numpty like me get a man who can in mate, be cheaper in the long run Think i'm gonna. And another to fit my hi flo cats and plenum Quote Link to comment Share on other sites More sharing options...
lomoto Posted December 9, 2006 Share Posted December 9, 2006 A connector that goes on the end of the cable to the lnb and on the other end that connects to your sky box. Very easy to fit Not for an electrical/mechanical numpty like me get a man who can in mate, be cheaper in the long run Think i'm gonna. And another to fit my hi flo cats and plenum you know it makes sense Quote Link to comment Share on other sites More sharing options...
