Beavis Posted December 8, 2006 Share Posted December 8, 2006 Does the cap give you any other benefits than looking good. I have read something about it giving you better cooling? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted December 8, 2006 Share Posted December 8, 2006 just looks really although it does have a higher blow off limit. Not sure that makes it better in cooling Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 8, 2006 Author Share Posted December 8, 2006 http://cgi.ebay.co.uk/NISMO-RADIATOR-CA ... dZViewItem AUTHENTIC NISMO 1.3kg/cm HEAVY DUTY RADIATOR CAP The Nismo radiator cap is a heavy duty radiator cap, which operates at 18.2 lbs (1.3 kg/cm) compared to 12.6 lbs (0.9 kg/cm) non-turbo and 16.8 lbs. (1.2 kg/cm) turbo Nissan OE(Original Equipment) stock caps. Provides more cooling than the standard radiator cap. Ok cheers Mike for that Quote Link to comment Share on other sites More sharing options...
M13KYF Posted December 8, 2006 Share Posted December 8, 2006 bought mine from these guys to Quote Link to comment Share on other sites More sharing options...
kerbside*motors Posted December 8, 2006 Share Posted December 8, 2006 If it is a real Nismo cap it will open at a higher temperature/pressure (like M13KYF pointed out) Tuned engines generally run slightly hotter and genuine Nismo caps will stop them blowing all their coolant out. They do not make the engine burn more fuel or air and they do not help the air in or the exhaust out so they are unlikely to create any noticable performance increase! Quote Link to comment Share on other sites More sharing options...
kerbside*motors Posted December 8, 2006 Share Posted December 8, 2006 ...but yes, they do look better than the Nissan one! Quote Link to comment Share on other sites More sharing options...
JDM Performance Posted January 5, 2007 Share Posted January 5, 2007 As stated, doesnt increase engine performance but will aid engine cooling on tuned engines. Available from stock for £28: http://www.funkystyling.co.uk/item_deta ... rodID=1978 ..or alternativaly, just keep your current cap and fit a nice cap cover for £17.95: http://www.funkystyling.co.uk/item_deta ... =449006477 HTH Chris Quote Link to comment Share on other sites More sharing options...
FUG Posted January 10, 2013 Share Posted January 10, 2013 What's the latest link for these products? Cheers Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted January 11, 2013 Share Posted January 11, 2013 What's the latest link for these products? Cheers Holy moly, five year thread resurrection! Try the usual suspects, Tarmac, CS, ZMANALEX, etc... Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted January 11, 2013 Share Posted January 11, 2013 What's the latest link for these products? Cheers Holy moly, five year thread resurrection! +1 wot BM said Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted January 11, 2013 Share Posted January 11, 2013 I wondered why Beavis had only just discovered the Nismo rad cap! Quote Link to comment Share on other sites More sharing options...
FUG Posted January 12, 2013 Share Posted January 12, 2013 What's the latest link for these products? Cheers Holy moly, five year thread resurrection! Try the usual suspects, Tarmac, CS, ZMANALEX, etc... Lol didn't want to start a new thread for sake of it so brought this one back from the dead! Thanks will drop them a pm Quote Link to comment Share on other sites More sharing options...
Beavis Posted January 12, 2013 Author Share Posted January 12, 2013 I wondered why Beavis had only just discovered the Nismo rad cap! I wondered why i had started the thread then saw the date! Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted January 12, 2013 Share Posted January 12, 2013 One thing must be said tho.... At least the OP used the search function Quote Link to comment Share on other sites More sharing options...
Wasso Posted January 13, 2013 Share Posted January 13, 2013 One thing must be said tho.... At least the OP used the search function +1 on that for sure. Apparently they're better for looks and hold more pressure as said above. Quote Link to comment Share on other sites More sharing options...
