marzman Posted June 29, 2011 Share Posted June 29, 2011 Hi all, I've had a slow puncture on my front right wheel since i got back from the 'ring a couple of weeks ago, so i took it to the garage this morning... He took the wheel off, and there is a small bulge on the inside edge of the sidewall... it's not immediately noticeable, but it is there... So anyway, we found the culprit to be a faulty valve (which he doesnt know how to fix?!), but regardless he said he wouldnt refit that tyre anyway due to the egg... To make matters worse, i have Goodyear Eagle F1 tyres fitted, but these have been replaced with the Assymetric versions, so the garage said they cant get any tyres the same as mine - so i have to either replace both front or all 4 tyres. So my questions in order are: 1. For a minor bulge in the tyre wall, is it necessary to replace the tyre? 2. Valves on Volk wheels... are they Volk specific or do any generic valves work? 3. Can anyone recommend a supplier for 1x Goodyear Eagle F1 tyre (non-assymetric). I have found one on eBay at £160, but cant find any on the usual supplier sites (camskill etc) Cheers. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 29, 2011 Share Posted June 29, 2011 Doesnt sound good bud - but an egg on the sidewall is an MOT fail I beleive and also not a good thing to have in general so they are right in making you replace it - no matter how annoying or expensive. Cant help on the other fronts I'm afraid. Quote Link to comment Share on other sites More sharing options...
glrnet Posted June 29, 2011 Share Posted June 29, 2011 Once a tyre wall has a bulge it is advisable to replace the tyre, you have a weak spot now and unfortunately no one could say if it will fail sooner or later so best to be on the safe side You don't want that blowing out at 80 on a motorway Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 29, 2011 Share Posted June 29, 2011 Egg (aka a bulge in the sidewall) is a tear in the structure of the tyre, so yes no matter how small it is dangerous and its there waiting for enough pressure to pop it at this weak point. As for Volk Valves, are they just a 90 degree valve? if so not many places stock them but you can just use a generic valve and leave the hole poking through the face of the wheel. In any case a standard valve is fine, I have never had a valve hole in an ally be a completely different size to standard. I have fitted everything from £30 shi**ers to £20,000 Brabus SLR alloys Get a picture up if you can of the valve. Quote Link to comment Share on other sites More sharing options...
marzman Posted June 29, 2011 Author Share Posted June 29, 2011 tez162003 said: Egg (aka a bulge in the sidewall) is a tear in the structure of the tyre, so yes no matter how small it is dangerous and its there waiting for enough pressure to pop it at this weak point. As for Volk Valves, are they just a 90 degree valve? if so not many places stock them but you can just use a generic valve and leave the hole poking through the face of the wheel. In any case a standard valve is fine, I have never had a valve hole in an ally be a completely different size to standard. I have fitted everything from £30 shi**ers to £20,000 Brabus SLR alloys Get a picture up if you can of the valve. Yeh thanks all, i hadnt thought about the MOT. Tez, sounds like a 90 degree valve, see the pic below. So you think just fitting a standard valve will work? Sounds like a plan... Quote Link to comment Share on other sites More sharing options...
Southernspeed Posted June 29, 2011 Share Posted June 29, 2011 How big is this egg and is it soft? Radial tyres don't always have smooth walls due to how they're made up and slight 'contours' on the wall are normal. If it's instantly see-able and can be poked like it's de-laminated then yes, it's dangerous. Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 29, 2011 Share Posted June 29, 2011 glrnet said: Once a tyre wall has a bulge it is advisable to replace the tyre, you have a weak spot now and unfortunately no one could say if it will fail sooner or later so best to be on the safe side You don't want that blowing out at 80 on a motorway CHANGE IT! After witnessing a car leave the outside lane into the hard shoulder at a 90 degree angle and smack right into the barrier at 70+. It wasn't pretty and could have taken out a number of cars in it's path to the hard shoulder barrier! (Heading from Port Solent to Maidstone) I wouldn't want to drive round on a tyre which could pop at any moment. It's for your own safety mate. A costly replacement but life is priceless. Quote Link to comment Share on other sites More sharing options...
marzman Posted June 29, 2011 Author Share Posted June 29, 2011 Wasso said: glrnet said: Once a tyre wall has a bulge it is advisable to replace the tyre, you have a weak spot now and unfortunately no one could say if it will fail sooner or later so best to be on the safe side You don't want that blowing out at 80 on a motorway CHANGE IT! After witnessing a car leave the outside lane into the hard shoulder at a 90 degree angle and smack right into the barrier at 70+. It wasn't pretty and could have taken out a number of cars in it's path to the hard shoulder barrier! (Heading from Port Solent to Maidstone) I wouldn't want to drive round on a tyre which could pop at any moment. It's for your own safety mate. A costly replacement but life is priceless. Cheers pal - i've found a replacement (same type) on eBay for only £160, so that should be turning up tomorrow. Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 29, 2011 Share Posted June 29, 2011 Good man - don't want to lose a fellow Azure Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 29, 2011 Share Posted June 29, 2011 yes you can use a standard valve, just means there will be a hole where the valve slots through the centre section Quote Link to comment Share on other sites More sharing options...
marzman Posted June 29, 2011 Author Share Posted June 29, 2011 tez162003 said: yes you can use a standard valve, just means there will be a hole where the valve slots through the centre section God man, thanks. Quote Link to comment Share on other sites More sharing options...
JetSet Posted June 29, 2011 Share Posted June 29, 2011 marzman said: I've had a slow puncture on my front right wheel since i got back from the 'ring a couple of weeks ago, so i took it to the garage this morning... He took the wheel off, and there is a small bulge on the inside edge of the sidewall... it's not immediately noticeable, but it is there... Yeah, a slow puncture will often lead to the tyre overheating and bulging especially if the pressure drops below 20. Had the same thing myself on my Zed 3 about years ago. Pete Quote Link to comment Share on other sites More sharing options...
marzman Posted June 30, 2011 Author Share Posted June 30, 2011 All fixed and back to normal... managed to find another tyre and got it fitted today... but my pocket is now £170 lighter. Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted June 30, 2011 Share Posted June 30, 2011 £170.... wince! Quote Link to comment Share on other sites More sharing options...
Jay Posted June 30, 2011 Share Posted June 30, 2011 Good man marz....... yeh 170 quid lighter just now....... but just imagine the cost if your tyre blew out while driving........... so really its a saving Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 30, 2011 Share Posted June 30, 2011 Jay said: Good man marz....... yeh 170 quid lighter just now....... but just imagine the cost if your tyre blew out while driving........... so really its a saving +1 might seem expensive but nothing compared to paying out if the worst had happened Quote Link to comment Share on other sites More sharing options...
