Clarkie Posted June 27, 2011 Share Posted June 27, 2011 Whenever I hit about 60mph I can hear the wind rushing in through the drivers window. If I press the shut window button, the window goes up about a millimetre and this stops the noise for about 5 seconds and then it starts again. If I go back down below this speed the noise stops too. Most of the time this isn't an issue as I have music up high but it is annoying. A mate suggested it was because there was no pillars on the window top allows the wind to get in by and force it open? Anyone else experience this? Quote Link to comment Share on other sites More sharing options...
Beau Posted June 27, 2011 Share Posted June 27, 2011 I had this exact problem. You will need to remove the door card and behind one of the black sticky labels there is a reset button for the window motor. I believe you have to press this and wind the window down and then release and wind it fully back up and it should shut properly. If you have any problems PM me. The instructions for this is on the 350z Manual. Quote Link to comment Share on other sites More sharing options...
Zugara Posted June 27, 2011 Share Posted June 27, 2011 window reset.... viewtopic.php?f=35&t=141&start=0 Quote Link to comment Share on other sites More sharing options...
magic84 Posted June 27, 2011 Share Posted June 27, 2011 it may also be the rubber at the leading edge of the window next to the wing mirror, make sure its not split Quote Link to comment Share on other sites More sharing options...
Clarkie Posted August 9, 2011 Author Share Posted August 9, 2011 Thanks guys, did the reset today. Straight forward enough. Fingers crossed. Just realised i've forgotten to put the black sticker back on... Hmmm Quote Link to comment Share on other sites More sharing options...
s28ben Posted September 7, 2011 Share Posted September 7, 2011 Hi Clarkie, I have the same problem you mentioned, did this reset solve the issue? Cheers, Ben Quote Link to comment Share on other sites More sharing options...
s28ben Posted September 19, 2011 Share Posted September 19, 2011 Have just tried this reset and it didn't solve the problem. Has anyone tried replacing the seal? Quote Link to comment Share on other sites More sharing options...
