Key question
chippy
Off to France tomorrow and try as I might, I cant find the spare key.
Is it possible to keep the fob and the key seperate and for either to still work without the other? Just trying to think up a backup plan in case the worst should happen.
Although you can open the car with the key part of the fob, you will still need the fob to start the car, theres no way to use the key on its own to start it. The idea is meant to be if the battery dies on the fob you can use the key to get into the car and then stick the fob in the "fobgina" and that can power the fob wirelessly to get codes to get the car started.
