Standard Intake
Jim350GT
I'm in Suffolk RT so if you do I could probably come pick it up. If you have any skinned bits about I wouldn't mind a nosey as I have a car I may fancy a few bits doing.
let me check tommorow, pm me to remind me tommorrow afternoon, snd i'll check when i get home. wifes car is blocking the door.
I think on the GT the stock airbox gives better results than an aftermarket kit from my readings. I've seen Alex sells the Cosworth filters. I'll probably just stick with stock as it does what it supposed to and flow differences will be marginal at the detriment to air quality. I have seen people use an internal adaptor on the airbox and then fit a cone filter inside?
