Leaking roof seals.....BAD....Ahhhhhhhhh....Help.
Zugara
Cheers Alex...... :scare::scare::scare:
I will PM you my VIN tonight.....Thats a tough pill to swallow :dry:
Are they renound for leaking just at the end of the seal where there is a little flap of rubber, which I assume gets pinched on the door card?
Will might know, didn't he have the same problem? :shrug:
Hmmmm, rings a bell, cheers graham. Will PM Will..... :lol:
Yup same problem, I had all the seals replaced by the garage, made it miles better but I still get leaks in now and again, hardly a trickle but annoying, tbh I've learnt to live with it..... :rant:
Those seals were very expensive yes, luckily the garage replaced them out of goodwill :)
I'd try some rubber lubricant on the seals first if they're just old rather than cracked (Holts do a good 1)... and for a couple of quid it's worth a go before splashing out loads on new seals. It worked on my old Mr2 T-Bar which leaked really badly before. :thumbs:
Cheers mate..... will try that, although I have tucked the offending rubber flap behind the door seal which seems to have solved the problem.
