Throttle control problems Throttle Body??
Beau
Hey guys, As your aware I have 2 lights coming up. The slip light and traction control light.
After reading the manual, throttle control problems could be one issue. I have heard that the throttle body can get dirty and this then needs cleaning. Has anyone done this?
Done plenty of times on here mate, use some solvent cleaner and a paint brush to clean it, dont move the valve plate tho :scare:
Searchy is your friend :thumbs:
Can I remove it completely?
I have read I will need to disconnect the negative terminal of the battery first though.
Cant see what the throttle body has to do with traction control and slip lights...... but no harm in cleaning it I guess!!! dont expect it to have any effect on your dash lights though :thumbdown:
well, accrding to the 350z manual, throttle control problems can give you both the traction control and slip light on your dash, so its worth a try!
Have you tried the throttle reset?
No, I have not. What is it? And I did add more braked fluid when I thought it was low previously....
