Radiators - AMS, Mishimoto, Koyo
Tarmac@TarmacSportz
Just a little thread of some of the brands I can get. Others available too.
AMS £265 Delivered
AMS 2" ALL-ALUMINUM RACING RADIATOR
• As featured in Sport Compact Car, Super Street, Modified, Turbo & High Tech Performance,
Performance Auto & Sound, and Nissan Sport magazines!
• Huge racing core - 50 mm (2â€) single pass vs. 15.8 mm (5/8â€) stock!
• Holds an extra 2 litres of coolant vs. stock!
• All-aluminum construction to ISO 9001 manufacturing standards
• One Year Limited Manufacturer Warranty!
• Over-sized, fully polished end-tanks
• 45 fins per square inch, allowing for less restriction across the core
• Thick-walled billet welded neck
• Extra thick flared inlet and outlet pipes, allowing for aggressive tightening of clamps
• OEM mounting points for fan assembly and A/C condensor (some additional trimming required)
• Aluminum drain plug
• AMS laser-etched logo
• AMS colour painted logo on both sides
• 1.3 high pressure cap included
koyo
V2577 1-7/16" (for limited space applications) All Koyo Radiators are fully polished to a mirror finish and are made from aircraft quality aluminum and Heli-arc welded. Even the end-tanks are made of aluminum, cores are NOCOLOK-brazed. Koyo Radiators provide 20% to 30% more cooling than standard radiators and can handles high revving, high performance motors.
Designed for manual transmission cars only.
Price tbc
Mishimoto £270 delivered
The Mishimoto performance aluminum radiator for the Nissan 350Z is designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions, and most importantly protect your car from overheating. Whether you drive your vehicle daily or take it for track runs. The Mishimoto aluminum Nissan 350Z radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks, enhancing the overall performance of your engine. Every Mishimoto aluminum radiator is a direct OEM fit, making installation effortless with no cutting or modification required, the ideal upgrade to the stock Nissan 350Z radiator. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap.
Overall Size: 29.7" x 21" x 4.45"
Core Size: 15.75" x 28.15"
Rows: 2
Inlet: 1.4"
Outlet: 1.4"
Core Thickness: 1.42"
Tank Wall Thickness: .08"
Fill Neck: 1.25"
Drain Plug Thread Size: (M16) .06"
Drain Plug Thread Length: .047"
Not suitable for HR engine applications.
Price £270 delivered
Why are you doing this to me everytime I look in your section theres something new I am interested in , your going to cause me and the girlfriend to break up soon with the amount of money am putting in to the zed :#1::lol:
Any way are these a direct replacement or would I need to modify the brackets ?
Can you do the hose kits as if I was changing the radiator I might as well upgrade the hoses ??
