ScanGauge II
bubbagross
Yep, got one fitted to mine permanently.
Find it useful (especially the DTE info which is far more accurate than the car's computer).
Got volts, DTE, intake temp and water temp as my four visible gauges, but plenty of others to choose from (speed, rpm, TPS, mpg, km/l and a few others). It's a bit limited on the info the ECU gives it compared to some cars (my XTrail gives a lot more info, such as EGR valve position etc)
Also works well scanning for error codes, but only works on UK cars (not JDM imports).
You can transfer between vehicles as well - if you have two cars, get the extra lead for it and you can use it in both and it remembers the info from both.
Simple to use and easy to set up.
You gone and bought a 370 ? ;)
Lincolnbaggie, thanks :teeth:
Where did you buy it from, found this lot on the web http://www.scangauge2.co.uk/ but in Greece, so a little dubious :wacko:
Also where have you mounted yours ?
Cheerz
Ebay ? :shrug:
http://cgi.ebay.co.uk/ScanGauge-2-extra ... 3a66565e3d
He hs a 350 - you have a 370? :shrug:
+1 - people please take not of the sections you are in and what posters are saying. 370z section is now a lot busier and we are getting a lot of small mis-reads/posts WRT 350z and 370z ;)
I dont know anyone in this country that has a Scanguage on a 370z, but be happy to try one out if a local 350z owner has one.
Cheerz
:lol: and I assumed as he'd answered he had a 370z :clap:
Would be good to confirm it all works OK before buying ... I'll drop the guy on ebay a message, see if he knows
Cheerz
His sig is a bit of a give-away, so I would call that '15 all' :bangin::lol:
