Suzanne the LS3 6.2 V8! Caution very long build thread....
Wasso
Chris, are you sure the hose isn't the wrong way round? part 2 to connect to the slave instead of part 1? pictures are not that clear of the pipe setup
Yes mate, Hose 2 is only 6 inches long and is the bleed line hose one is long enough (just as it's from a LHD kit) to go to the new master cylinder and has a banjo connector fitted to connect to it.
Also the new kit has a push and clip connector with rubber O ring both the ones on the box are threaded so it's just different fitments, hopefully I can get a couple of adapters to do the conversion.
  • Like 2
Adrian, that's a bit harsh :scare:
Yeah, go swanning off to California, then come back here criticising the workers :stir:
What workers are you talking about?!?!
27 of you and you only managed to take some bolts off to remove the engine? :lol: :lol:
That's SNAIL SPEED!!! :lol:
We were busy talking about you behind your back :p
LA LA LA LA LA LA...
Get it? :lol:
Ok cool, I wasn't doubting you, just wasn't clear in the pictures, sure you will get something fabricated :thumbs:
Evening all and Wasso :lol:
So went down to see the boys at Thread and Pipe - we sort have got a solution 50% seems good the other bit did not quite work out so I did a bit of fabricating,
This is what I have
It is basically a very long bleed nipple, it needs to be remote to allow clutch bleeding after the LS and box goes in the 350 so .....
i cut the end off
Drilled it out
Then welded the new adapter from Thread and Pipe onto the end
Drilled the other end out so it is no longer a bleed valve but now just an extension pipe
Cleaned it up
bit of paint
That's pipe 1 ready - Onto pipe 2 as made by the boys
Bent to shape
All installed - Inside the box
coupled to new braided lines
Then I pulled the dash apart
and the wiper covers came out
All to get at this
Got it out ready to modify the replacement Wilwood with some of the stock parts
More soon(ish)
Is it in yet? (She said).
=p get your own material!
Ahhh bugger... Nothing worse than passing someone else's joke off as your own! I didn't see it I swear :p
Well don't click to the last page without reading!! :p
  • Like 3
I like my progress threads how I like my books - no words, lots of pictures ha! :dummy:
Back on topic - is it in yet?
Not quite, but it might be this weekend ;)
Good evening, Good evening, Good evening -
No update last night as I was playing on Hissing SID (my 370z for anyone that didn't know)
But tonight I had a play on Suzi :teeth:
So to start I finished the braided line on the clutch slave, just neatened up the outlet,
Then onto the work bench with the rest of the Sikky clutch upgrade kit and the previously removed 350 master cylinder, (and very important cup of coffee)
First I took a measurement
11cm from the face to the center of the pin (noted that down)
then you have to strip both down a bit
Done :thumbs: (and some coffee drunk)
Assemble the Wilwood cylinder with parts from the 350 cylinder
Done :)
Adjust to the previously noted 11cm on centre
Tighten up, re-join the reservoir with the supplied pipe and adapter
Done
jobs a good un :thumbs: (coffee finished :thumbdown:)
Bolt it into the car what a PITA that is!
Then realise the kit won't fit properly - normal for modifications like this, so I "modified" Suzi's body work a bit
a slight stretch to allow the banjo bolt space to fit - like so -
Finished job looks like this,
Edited by Keyser
