What cheap/free clean/work can I do on my engine?
slimjim
Following Riceys thread here.... viewtopic.php?f=10&t=50251&start=0
about if he should or should not clean his butterfly in his throttle body....
What CAN I do to my car to make sure it runs longer... and is nice and reliable.
Going past the normal fluid changes.....
Just been down to see a friend who has air-hosed my cone filter try to get it a little cleaner and I SWEAR it sounds louder now.
So... is there anything I can do to help my car... long term? :wacko:
Is this kinda stuff rubbish?
Sounds like the engine flush thread we had the other day, i.e: taking all the nasty stuff sitting safely out of harms way and moving it around the engine where it may do damage... never had any experience with it though.
i like the ecotek boost foam, i used it on an old car and plan to do it to the jag. it cleans off carbon in the detonation area. i.e. its sprayed in after the MAF and burnt off in the combustion taking the carbon with it.
not disimiliar to injector cleaners that are put in through the fuel tank.
Number up your HT Leads just in case you get them the wrong way around :thumbs:
Yeah, do that anyway bud.
always make sure the oil is warm before flooring it.
Ha Ha Ha!! Thing is, I did that WAY before Ian did :lol:
Won't be doing it again....
On one of my old cars, I used a dremmel and ground down the inside of my plenum/manifold intake. To be fair, this was because the original design was pants on the Volvo 440 :blush:
Nothing like that I can do?
Hey hold on a mo here.... I wasn't in control of HT leads, ask Bennett :doh:
I wouldnt go messing with the inlets myself - I matched a inlet manifold to the inlet ports on a 200SX a few years ago, but thats because the original casting was SHOCKING - if you get it wrong you can do more harm than good. :scare:
Not a dig mate. It is such an easy mistake to make. We have all done it. HT Leads always used to be numbered at manufacture but they have stopped doing this in recent years. After your experience, think it is a good thing for everyone to do :thumbs:
I cleaned the throttle body as you mentioned on my thread Jim. It was pretty crapped up but white spirit and a bit of cloth soon sorted that out!
Is your cone an oiled one?
Was talking to a friend of mine who knows what he is talking about (he is rebuilding a 200ZX to stage 4 c550whp at the mo) and he said that if your cone is an oiled on, that might be the reason your throttle body was "Caked up" ... just from the excess oil being sucked through it.
Not sure bud. It's just a normal jtw pop charger that bought off ekona :shrug:
they are oiled as standard ;)
Well, there you go, that could be the answer.
When did you last clean the cone?
Mine is a paper cone.... but it isn't a jtw.
