notfub Posted June 5, 2011 Share Posted June 5, 2011 I’ve been reading and searching the ICE section for answers to these two questions but I’m still unsure...... Q1. If replacing the Bose HU with a replacement HU with in-built Bluetooth, can you use the original factory Bluetooth Mic? Is the Mic input to the standard Bose obvious when you take the Bose out? Q2. If I replace just the front speakers (4ohm) will this cause me problems as the Bose Amp expects a lower resistance? There’s no confirmation on the Ohm rating of the standard Clarion speakers. Am I likely to damage the new components? I intended to replace the front door speakers first, then, as funds allow, the head unit, and then install a 4 channel amp, 8 or 10†Sub and bridge the amp to run 3 channels. Am I better off just saving up the £ and doing it all together? At least I can leave the standard wiring in place and re-install the standard setup when selling. Thanks for your help Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 6, 2011 Share Posted June 6, 2011 think the mic goes to the bluetooth main unit in the secret compartment under the glovebox and then back to the HU. Quote Link to comment Share on other sites More sharing options...
notfub Posted June 6, 2011 Author Share Posted June 6, 2011 think the mic goes to the bluetooth main unit in the secret compartment under the glovebox and then back to the HU. Thanks for the info Mike, I can trace & identify the wires far more easily now I know that Quote Link to comment Share on other sites More sharing options...
