Gavalar Posted June 2, 2011 Share Posted June 2, 2011 Hi all, I need a little help please, I am new to owning a 350Z, and need to do some basic checks on my car, and I cannot find any where in my documentation what my tyre pressures should be. Inside the drivers door there is the usual guide, but this relates to tyres of a different size to those fitted to my car. I have 275/35 R19 96W on the rear, and 245/35 R19 93Y on the front. Help anyone? Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 2, 2011 Share Posted June 2, 2011 What tyres do you have on now, with regards to make not size? Tyre pressure is dependant on that far more than the size of the tyre itself. That said, 35psi front and back isn't a bad place to start and isn't going to put you in a ditch. Welcome along btw, get some pics and a post up in the Introduction section! Quote Link to comment Share on other sites More sharing options...
Gavalar Posted June 2, 2011 Author Share Posted June 2, 2011 Hi Ekona, thanks for the response, at least I have aplace to start from as you say 35psi. I will also get some pics up asap cheers Quote Link to comment Share on other sites More sharing options...
Beau Posted June 2, 2011 Share Posted June 2, 2011 I have 265 35 19 front and 285 35 19 rear and use 30psi all round, good comfort and grip! Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 2, 2011 Share Posted June 2, 2011 As I said, it depends on the tyre. 30psi would be fine for something like the PS2s, but it'd feel like treacle on FK452s. Quote Link to comment Share on other sites More sharing options...
Stu350z Posted June 3, 2011 Share Posted June 3, 2011 I'm run my Dunlop Sport Max at 36psi and there 245's and 275's on 19's! They feel perfect for me! Quote Link to comment Share on other sites More sharing options...
Windy Posted June 3, 2011 Share Posted June 3, 2011 Hello, 35psi seems to be the norm. I've had my tyres filled with nitrogen, so hopefully the pressure will stay steady for at least 6 months with no need for topping up!!! (s'wat the garage said). Quote Link to comment Share on other sites More sharing options...
buster Posted June 3, 2011 Share Posted June 3, 2011 i run 35psi front and rear ......245/35/19 and 275/35/19 Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 3, 2011 Share Posted June 3, 2011 If you wanna know 'bout tyres on a 350Z. Ekona is your man Quote Link to comment Share on other sites More sharing options...
kenc543 Posted September 7, 2011 Share Posted September 7, 2011 As I said, it depends on the tyre. 30psi would be fine for something like the PS2s, but it'd feel like treacle on FK452s. hi got told ur the person for tyre pressure just wondering what tyre pressure should i put in my tyres there 255/30zr20 thanks Quote Link to comment Share on other sites More sharing options...
Ekona Posted September 7, 2011 Share Posted September 7, 2011 What tyres are they, and are those sizes on the rear or the front? Quote Link to comment Share on other sites More sharing options...
rdsprint Posted September 8, 2011 Share Posted September 8, 2011 When serviced by Nissan they put 34psi in all four. Quote Link to comment Share on other sites More sharing options...
Spidermonk Posted September 9, 2011 Share Posted September 9, 2011 I seem to remember reading that the 350z have tyre pressure monitors and a light on the dash will illuminate when they need topping up? Is it still recommened to manually check them or do most people just wait until the light comes on? Quote Link to comment Share on other sites More sharing options...
Ekona Posted September 9, 2011 Share Posted September 9, 2011 350Z in the UK and JDM (not sure about the US) don't have tyre pressure monitors, and even if they did you still still manually check your tyre pressures roughly every fortnight. Get a cheapy gauge from Halfrauds, will be good enough for the 2 min job Quote Link to comment Share on other sites More sharing options...
coldel Posted September 9, 2011 Share Posted September 9, 2011 I put 35psi into my falken 452s and it feels a little too much, they had dropped to 31psi when I topped it up but was certainly nice and comfy! Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted September 9, 2011 Share Posted September 9, 2011 Hi all. Welcome to the Zed club Gavalar. I have MPS3s, i have recently replaced my rear tyres. they wore a lot more in the centre of the tyre than on the edges. I'm not going to lie, i drive the car hard and the tyres are often a nice tepid warm temperature by the time i arrive. The wear in the centre of the tyre makes me wonder if im running them too high pressures. I have the cold pressures at 35psi as suggested on here. im wondering if i should lower the pressures a little but i dont want to be overheating them or getting any snap oversteer at high speed from having them to low. they are VERY grippy and often on smooth roads make the Zed feel allmost wallowy. any pointers as to whether i should change pressures please comment. also im struggling to find any info on optimum operating temperatures etc oh, and they are 40 profile all round. Quote Link to comment Share on other sites More sharing options...
Ekona Posted September 9, 2011 Share Posted September 9, 2011 If you're happy with the pressures then leave them as-is. I've never used the PS3 on the Zed as the PS2s were so much better, but assuming that they have the same hard sidewall as most Michelin tyres if it was me I'd be running 33/34 F/R. That's just me though, if you're happy then stay with that, a few psi here or there won't make too much difference. Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted September 9, 2011 Share Posted September 9, 2011 i thought the PS2s have been replaced by the supersport now? need to look into the range next time as i will have to change all 4 Quote Link to comment Share on other sites More sharing options...
Ekona Posted September 9, 2011 Share Posted September 9, 2011 Correct. Quote Link to comment Share on other sites More sharing options...
