slimjim Posted June 1, 2011 Share Posted June 1, 2011 Just had an unexpected "day off" thrust upon me... Thought I might use tonight to take the front bumper off my car and have a look at my leaking PAS rad. Couple of questions. 1. How hard is this to do? 2. How hard is this to do ON YOUR OWN? 3. How easy is it to put back on, ON YOUR OWN? 4. If the bumper is off, is it legal for me to drive with it off? (Not that I am going to, just interested) Cheers Quote Link to comment Share on other sites More sharing options...
slimjim Posted June 1, 2011 Author Share Posted June 1, 2011 I have this... http://www.350z-tech.com/wiki/index.php ... _%28G35%29 and this... viewtopic.php?f=35&t=19516 Anyone want to comment at all? Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 1, 2011 Share Posted June 1, 2011 Chesterfields Guide is the one I used. It's very straight forward. The only techincal part is accessing the press studs behind the front wheels. This will allow you access behind the wheel arch lining where the wing meets the bumper there will be two bolts. These are the trickiest bits for removal and fitting. It takes less time if there are two of you, but it's not necessary. You can drive with your bumper off, but I wouldn't say the police would look kindly towards it. It'd look gastly too Quote Link to comment Share on other sites More sharing options...
AK350Z Posted June 1, 2011 Share Posted June 1, 2011 Easy once you find all the pop-studs and take the washer jets out. The bumper then just lifts off. It took me a cautious hour or two to change my front reflectors. Quote Link to comment Share on other sites More sharing options...
slimjim Posted June 1, 2011 Author Share Posted June 1, 2011 Cheers... Two of the guys I trust most on the forum replying with exactly what I wanted. Sweeeeet Quote Link to comment Share on other sites More sharing options...
AK350Z Posted June 1, 2011 Share Posted June 1, 2011 Cheers... Two of the guys I trust most on the forum replying with exactly what I wanted. Sweeeeet Sucker! Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 1, 2011 Share Posted June 1, 2011 It's actually really difficult and you need to remove the radiator, wheels, suspension etc in order to remove the bumper Quote Link to comment Share on other sites More sharing options...
AK350Z Posted June 1, 2011 Share Posted June 1, 2011 It's actually really difficult and you need to remove the radiator, wheels, suspension etc in order to remove the bumper Still easier than changing a few sparkplugs though eh Ian? Quote Link to comment Share on other sites More sharing options...
cmck13 Posted June 1, 2011 Share Posted June 1, 2011 The guys have already said it all, I was in the same position last year. Some are very easy, some are a pain in the bottom, depending on how many of the 10mm screw are seized etc. I found it much easier for access to take the front wheels off otherwise any one with hands bigger than a 10 year old usually ends up with ragged bit of blooded meat hanging of them. A couple of hours on your own plus a bit extra looking for the place that a few bolts and studs that you have found left over. Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 1, 2011 Share Posted June 1, 2011 It's actually really difficult and you need to remove the radiator, wheels, suspension etc in order to remove the bumper Still easier than changing a few sparkplugs though eh Ian? It would have been any easy task had it not been for Quote Link to comment Share on other sites More sharing options...
slimjim Posted June 1, 2011 Author Share Posted June 1, 2011 It's actually really difficult and you need to remove the radiator, wheels, suspension etc in order to remove the bumper Still easier than changing a few sparkplugs though eh Ian? It would have been any easy task had it not been for Pretty sure I can match you there... I changed some sparkies and put the leads back on teh wrong way! got 6 and 5 the wrong way round or something... Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 1, 2011 Share Posted June 1, 2011 It's actually really difficult and you need to remove the radiator, wheels, suspension etc in order to remove the bumper Still easier than changing a few sparkplugs though eh Ian? It would have been any easy task had it not been for Pretty sure I can match you there... I changed some sparkies and put the leads back on teh wrong way! got 6 and 5 the wrong way round or something... Exactly what happened in Wales..... Quote Link to comment Share on other sites More sharing options...
slimjim Posted June 1, 2011 Author Share Posted June 1, 2011 DOH! Realised as soon as I had done it mind Quote Link to comment Share on other sites More sharing options...
Wasso Posted June 1, 2011 Share Posted June 1, 2011 It took Darren B a further 90 mins to work out how and why we still had a problem despite replacing all the plugs. But the problem was found Quote Link to comment Share on other sites More sharing options...
