stuarty Posted May 31, 2011 Share Posted May 31, 2011 Ive recently had a go at detailing my Zed. I'm really pleased with the way it turned out! I bumped into a good friend the other day, who is a top class spray painter. He commented on how well my car was looking and offered to machine polish it for me. He said that he would clean it down with a solvent cleanser then using a very fine grade wet paper remove any debris thats left. Then he would machine polish the whole car and Finally machine wax and then hand wax the car with a silicon free wax. Any thoughts/ opinions on this as i'm not sure? Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 31, 2011 Share Posted May 31, 2011 For free? And he's good? Snatch his arm off Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 31, 2011 Share Posted May 31, 2011 Sandpaper Why not clay the car? Quote Link to comment Share on other sites More sharing options...
rancer Posted May 31, 2011 Share Posted May 31, 2011 Could be risky.. get him to do mine first and i'll let you know how it goes! Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 31, 2011 Share Posted May 31, 2011 Sandpaper Top-end guys regularly use it for the ultimate finish, takes a lot of skill to do though as you can imagine! A clay won't touch what a good papering can do. Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted May 31, 2011 Share Posted May 31, 2011 Unless he really knows what hes doing with sandpaper I would steer clear unless you have seen examples of his work - and polishing is a totally different art to being a good sprayer. Most painters will be used to the normal G3 after a paint to get rid of any small imperfections where as 'detailers' will often do a lot more than just use some G3 I would start of with a clay bar followed by a mild polish. They would sort a good majority of the defects. See what its like and if you want to go for an abrasive polish do so then seal and wax it. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 31, 2011 Share Posted May 31, 2011 Unless he really knows what hes doing with sandpaper I would steer clear unless you have seen examples of his work - and polishing is a totally different art to being a good sprayer. Most painters will be used to the normal G3 after a paint to get rid of any small imperfections where as 'detailers' will often do a lot more than just use some G3. +1 and to what Dan said above too. Wet sanding is only required if you have orange peel, and it will take a reasonable amount off already thin laquer, so I would only do it if the orange peel is really obvious or on panels that have been resprayed. Quote Link to comment Share on other sites More sharing options...
Ricey Posted May 31, 2011 Share Posted May 31, 2011 Zed paint is really thin - make sure he uses a mirconimeterythingymabob to check the paint depth if you do let him loose. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 1, 2011 Share Posted June 1, 2011 Any sprayer worth his salt, will always nib and machine polish,after a spray job, IE go over the whole car with 1500 or 2000 grade wet n dry abrasive paper, and then something like G6 or similar for a final polish. If they just use G3 steer well clear, as that just a bodge! I have machine polished my 350GT twice now, with a very fine compound, looking at the paint thickness it may just take a quick go with 2000 before polishing, but i wouldn't want to push it really. Quote Link to comment Share on other sites More sharing options...
stuarty Posted June 1, 2011 Author Share Posted June 1, 2011 Thanks for the advice everyone! Yeah the guy is really good, he's an independent, but he does alot of repair work for the dealers around were i live. My brother in law was trading in his burgandy vectra for an insignia. There was damage to the front bumper and loads of scatches and buff marks from trees on the drivers side. I got my friend to repair and paint the bumper and machine polish the whole car. My brother in law couldnt believe the difference and ended up keeping the vectra. Ive already clayed the car, then used Autoglym High definition cleanser, hand polished it with super resign polish and finished it off with two coats of high definition wax. As i said im really happy with the finish, but my friend could see a few blemishes. Quote Link to comment Share on other sites More sharing options...
