Z-Boy Posted May 28, 2011 Share Posted May 28, 2011 Hi Just a quick one! How do the front wing indicators come off, do they just pop out or do I have to take the wheel liner off to get them out. Thanks Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted May 28, 2011 Share Posted May 28, 2011 The clips can easily break, if you take a few of the poppers from the archliner out you can get access to the back and then pop them out from the rear. My clips broke so I just used clear silicone to stick them back on!! Quote Link to comment Share on other sites More sharing options...
Z-Boy Posted May 28, 2011 Author Share Posted May 28, 2011 Thanks for the quick response Quote Link to comment Share on other sites More sharing options...
veilside z Posted May 28, 2011 Share Posted May 28, 2011 you can pull them out from the wing enough to slide a credit card behind, then push the spring loaded clip in and at the same time gently ease out. the end will pertrude out. careful though as only one end of clip has give whilst the others fixed. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted May 28, 2011 Share Posted May 28, 2011 you can pull them out from the wing enough to slide a credit card behind, then push the spring loaded clip in and at the same time gently ease out. the end will pertrude out. careful though as only one end of clip has give whilst the others fixed. This is the correct way, they do this method at the stealers. Quote Link to comment Share on other sites More sharing options...
Z-Boy Posted May 29, 2011 Author Share Posted May 29, 2011 Thanks for the reply, but which side has the spring clip on it? Thanks Quote Link to comment Share on other sites More sharing options...
veilside z Posted May 29, 2011 Share Posted May 29, 2011 dont know it depends which way they snapped it in at manufacture. the lamp can be swivelled 180 degrees you see so it fits either way up thus putting sprung clip towards the front or towards the rear. when you slide the credit card behind it should pass further behind the sprung edge. Quote Link to comment Share on other sites More sharing options...
Z-Boy Posted May 31, 2011 Author Share Posted May 31, 2011 Actually there is a clip either side of the wing indicators and i suggest anybody trying this tries the other side if the first side they try is a bit stiff. Using a Credit Card worked a treat. Thanks all. Quote Link to comment Share on other sites More sharing options...
veilside z Posted May 31, 2011 Share Posted May 31, 2011 glad you did it without damage Quote Link to comment Share on other sites More sharing options...
