jumping350 Posted May 25, 2011 Share Posted May 25, 2011 Hi came across a set of wheels with this diameter 5x114 (says nissan fitament) 3.5 ET (dont know what ET is??) 18 inch rim says rim width is 8.75j (not sure as wouldnt the rears be different width to front??) 8" front 9.5" rear would these fit the Z without spacers etc and what tyre size would i need??? any help would be appreciated Quote Link to comment Share on other sites More sharing options...
marzman Posted May 25, 2011 Share Posted May 25, 2011 ET is the offset, i.e. mounting depth. The ET for the wheels you describe will be 35, not 3.5... 35 is unlikely to clear your brakes (assuming you have brembos) without spacers. Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted May 25, 2011 Share Posted May 25, 2011 Hi came across a set of wheels with this diameter5x114 (says nissan fitament) 3.5 ET (dont know what ET is??) 18 inch rim says rim width is 8.75j (not sure as wouldnt the rears be different width to front??) 8" front 9.5" rear would these fit the Z without spacers etc and what tyre size would i need??? any help would be appreciated This might help explain things a bit http://www.raceandroad.com/technical-he ... ffset.html Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 25, 2011 Author Share Posted May 25, 2011 thanks , i have non brembos so would that be ok for my car?? Quote Link to comment Share on other sites More sharing options...
RisingPower Posted May 25, 2011 Share Posted May 25, 2011 Do you mean an ET of 35? It's the offset in mm (doubt it's 3.5mm). 8.75j? Surely 8j for the front and 9.5j for the rear? If so, the front would be awful and I'm not sure it would even clear brembos (5mm less clearance and further in than stock), rear would be pretty poor also. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 25, 2011 Author Share Posted May 25, 2011 must be 35mm and put a decimal in by accident. it says 8" fromt 9.5" rear but also has that 8.75j in message not sure if that was eant to be there?? so even if right not worth the bother if it compromises handling etc??? im wanting 18s have not go brembos so could you reccomend a fitmant spec where i dont have to use spacers?? Quote Link to comment Share on other sites More sharing options...
RisingPower Posted May 25, 2011 Share Posted May 25, 2011 must be 35mm and put a decimal in by accident.it says 8" fromt 9.5" rear but also has that 8.75j in message not sure if that was eant to be there?? so even if right not worth the bother if it compromises handling etc??? Well, it would look rubbish, you'd have to run some odd tyre sizes and they're probably even heavier. The touring 18"s are et 30, 8j, 225 at the front, 245 at the rear. You can get many, many suggestions on fitment. Maybe something like rota gtrs in 8.5" et 25, 9.5 et 12 would be quite conservative, shame the fronts don't seem to have a reasonable offset available (something ~20/lower would be better). Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 25, 2011 Author Share Posted May 25, 2011 hmmmm this is getting confusing so basically look for some wheels with an offsett of -20 for fronts most wheels ive seen have 8" front 9.5" rear so thats what ive been going for and will carry on doing Thanls for help the search continues......... Quote Link to comment Share on other sites More sharing options...
RisingPower Posted May 25, 2011 Share Posted May 25, 2011 hmmmm this is getting confusing so basically look for some wheels with an offsett of 30 most wheels ive seen have 8" front 9.5" rear so thats what ive been going for and will carry on doing Thanls for help the searxh continues......... Urr...... Same offset and width as stock = stay inside the arches like stock, i.e. why bother if you're not going to run spacers? http://www.1010tires.com/wheeloffsetcalculator.asp That, maybe ask rarerims and have a look at the wheels sticky. And have a look at my350z's wheel threads: http://my350z.com/forum/wheels-and-tire ... index.html I also don't think you mean -20. You mean +20. Negative offset is not what you're after. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 25, 2011 Author Share Posted May 25, 2011 cool thanks for help il have a read around and run another diameter past you all before i buy some wheels Quote Link to comment Share on other sites More sharing options...
Ian Posted May 25, 2011 Share Posted May 25, 2011 -20 offsets would be epic Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 25, 2011 Author Share Posted May 25, 2011 heres one for you, what about those universal multifit rims with like 8 bolt holes??is the Z a common size that would fit this supposedly universal fitament??as long as offset is correct if i get spacers would that help with offset issues??i cant find (except for proper expensive) wheels with less than 30mm ET sorry for mad questions just trying to see what i can get away with without and with a spacer Quote Link to comment Share on other sites More sharing options...
RisingPower Posted May 26, 2011 Share Posted May 26, 2011 heres one for you, what about those universal multifit rims with like 8 bolt holes??is the Z a common size that would fit this supposedly universal fitament??as long as offset is correctif i get spacers would that help with offset issues??i cant find (except for proper expensive) wheels with less than 30mm ET sorry for mad questions just trying to see what i can get away with without and with a spacer Guhhh?!? I just don't get what you're after, there are plenty of rims with less than 30mm et which are sensibly priced. Have you asked rarerims? If you don't absolutely have to have 18"s: http://cgi.ebay.co.uk/Rota-GTR-19-alloy ... 35b231dcee Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 29, 2011 Author Share Posted May 29, 2011 right found a set of rota gtrs that have come off a 350z im even more confused now than ever!!!!here are the dimensions:front 9" ET 35 rears 10" ET 30 These seem to be the rims for the 350z everywhere i look for them, however in above post was mentioned 35mm ET was no good for car, but these as you can see have them, are these gonna be ok for my car??????? Quote Link to comment Share on other sites More sharing options...
Blacky Posted May 29, 2011 Share Posted May 29, 2011 right found a pair of rota gtrs that have come off a 350z im even more confused now than ever!!!!here are the dimensions:front 9" ET 35 rears 10" ET 30 These seem to be the rims for the 350z everywhere i look for them, however in above post was mentioned 35mm ET was no good for car, but these as you can see have them, are these gonna be ok for my car??????? They will fit your car but would but will sit into the arches. Ideally you want wheels around et20 or a bit less. You could use spacers to bring the wheels out a bit but with so many choices I would find some with decent offsets. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 29, 2011 Author Share Posted May 29, 2011 there actually being given to me at a very good price if i was too look for ones with right ET would probably pay hell of a lot more, they are 18s by the way if that helps at all, Are spacers available for this ET then??how much are they really?? Know what your saying about ET but if they go on and look nice with not to much worry then im happy Quote Link to comment Share on other sites More sharing options...
Jay Posted May 29, 2011 Share Posted May 29, 2011 Lol dude...... do a bit of research..... this topic has been discussed sooooo many times. The size of your wheel ie 18 inch will not matter. Plus if they have came off a 350z.... then you shouldn't really have anything to worry about. Spacers for the 350z come in 10, 15, 20 or even 25 I think.... so if you are not happy with the stance at ET 35 on the rotas, you could put a 15mm spacer on and it would be flush with the wheel arch...... which most people aim for Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 29, 2011 Author Share Posted May 29, 2011 Cool thanks for help i did try research lol but also get told a lot of stuff that conflicts so after doing that since 6am this morning thought would be quicker just to give my problem and get a response as i gotta make a decision or somene else will have them. Cool i can get a spacer through someone anyway so 15mm it is then Looks like il get them then yay new wheels finally Quote Link to comment Share on other sites More sharing options...
Jay Posted May 29, 2011 Share Posted May 29, 2011 No worries mate. There are plenty of traders on here who will sort you out with some spacers to suit your new wheels Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 29, 2011 Author Share Posted May 29, 2011 nice il look around, gotta get those 17s off even my girl said it was crying out for wheels productive week new exhaust and new wheels ......what next Quote Link to comment Share on other sites More sharing options...
Jay Posted May 29, 2011 Share Posted May 29, 2011 Body kit Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 29, 2011 Author Share Posted May 29, 2011 haha speaking of which got N1 kit sitting in my room, maybe trial fit before weather switches again Quote Link to comment Share on other sites More sharing options...
