mick43 Posted May 22, 2011 Share Posted May 22, 2011 any starting recommendation - other than let a few pound out and work from there... I've standard Rays and tyre fitment (Potenza)... and it looks to be a hot day Quote Link to comment Share on other sites More sharing options...
Beau Posted May 22, 2011 Share Posted May 22, 2011 I think 28 or 30 psi is good.... Quote Link to comment Share on other sites More sharing options...
captain Posted May 22, 2011 Share Posted May 22, 2011 I've always done a session on 35 and then copied what more experienced racers are doing. A couple of weeks ago the pressure read 42 after 15 minutes so I took them down to 37ish (hot) so if you want to start with lower pressure, I'd say 30. Might pop in to Combe on the way back from Abbey so I'll say hi if I see you. Quote Link to comment Share on other sites More sharing options...
Neilp Posted May 22, 2011 Share Posted May 22, 2011 I've always done a session on 35 and then copied what more experienced racers are doing. A couple of weeks ago the pressure read 42 after 15 minutes so I took them down to 37ish (hot) so if you want to start with lower pressure, I'd say 30. Might pop in to Combe on the way back from Abbey so I'll say hi if I see you. I always keep my tyres at 35psi on track and adjust through Quote Link to comment Share on other sites More sharing options...
