chrisgunton Posted May 20, 2011 Share Posted May 20, 2011 Ello, Bought the car in December, not sure about it's service history but has passed it's most recent MOT and had a health check by Nissan and passed with flying colours. But I noticed when checking the oil that the belts looked worn... It's got 42k on the clock. Should I get it serviced? With a missing service book I'm not sure what level it needs. Advice? Quote Link to comment Share on other sites More sharing options...
scubapics Posted May 20, 2011 Share Posted May 20, 2011 Best get the belts changed. If you don't know the service history then go for a full P3. Best to be safe than sorry. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted May 21, 2011 Share Posted May 21, 2011 If you have no proof that they have been changed at 42k then change them. The recommended time varies from one site to another. A P3 service should have shown up any issues of wear, I would check the paperwork for this. ZMANALEX is selling the two belts at around £29ish, its any easy enough DIY job and there is a good guide attached that shows the whole process. viewtopic.php?f=35&t=16644&start=0 Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 21, 2011 Share Posted May 21, 2011 swap them out DIY style, worth the small cost for reassuance and piece of mind, if it does snap you won't be happy and the cost of repairs will be a whole lot more than the belt costs Quote Link to comment Share on other sites More sharing options...
scubapics Posted May 21, 2011 Share Posted May 21, 2011 swap them out DIY style, worth the small cost for reassuance and piece of mind, if it does snap you won't be happy and the cost of repairs will be a whole lot more than the belt costs Why do you think the cost of repairing would be more expensive if the belts snap? The belts on the Z don't drive the camshaft so you're not looking at bent valves or dented piston heads. Power steering would fail but not cause a repair unless through lack of steering you write the car off. Water pump failure but you would have stopped the car because of the power steering issue so not a big probability of over-heating. The battery light would also come on because the alternator isn't being driven. For the other belt you would miss the air conditioning but still no costly repairs to be had. I'm not an expert by any means so maybe I missed something out? DIY job is easy, if you have ramps or axle stands and a simple socket set and providing the bolts on the undertray aren't seized. I didn't have any problems with my bolts though and haven't heard of any such problems. If you are mechanically inclined then certainly go DIY. You'll also realise how easy it is to do your own oil changes. Before you know it, you'll be changing the plugs too. Then you'll wonder why you pay Nissan hundreds of squids for a P3! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 21, 2011 Share Posted May 21, 2011 Water pump is chain driven so one less potential issue to worry about. Alex Quote Link to comment Share on other sites More sharing options...
scubapics Posted May 21, 2011 Share Posted May 21, 2011 Nice one Alex for putting me straight on that one Quote Link to comment Share on other sites More sharing options...
