chocohercules Posted May 19, 2011 Share Posted May 19, 2011 Hi Guys, just need to pick your brains for a minute....... Does anyone know if the Hub Carrier changed over the years? i think i have the correct name? Its the curved bar that the hub sits on the end of? e.g: is the Facelift model different to pre facelift? U.K spec different to JDM. As i might need to get one as one of the wheels is at a slight slant after the shunt. Any info much appreciated cheers guys Quote Link to comment Share on other sites More sharing options...
Beau Posted May 19, 2011 Share Posted May 19, 2011 I am 99% sure that they are all the same mate! Quote Link to comment Share on other sites More sharing options...
TADDY Posted May 19, 2011 Share Posted May 19, 2011 Some have a 12mm ball joint and some have a 15mm ball joint. Not sure which one has which though lol Quote Link to comment Share on other sites More sharing options...
Beau Posted May 20, 2011 Share Posted May 20, 2011 Some have a 12mm ball joint and some have a 15mm ball joint. Not sure which one has which though lol Ohh The facelift models have the bigger ball joint including the GT4. I have just swapped mine though for a 12mm when it was meant to be a 15mm. Had no issue so I guess it does not matter too much? Quote Link to comment Share on other sites More sharing options...
TADDY Posted May 20, 2011 Share Posted May 20, 2011 Mines not a facelift and I have a 15mm can you really use a 12mm where it was originally 15mm??? Would be handy to know as mine has gone. Quote Link to comment Share on other sites More sharing options...
