Car wont start... little help?
slimjim
Not driven my car for about 5 days.
Remote unlocks the doors. Get in, interior lights are fine.
Key in, ignition comes on. Dash lights up fine.
If I turn the key WITHOUT the clutch down, nothing happens (as you would expect)
If I turn the key WITH the clutch down, I get a bit of a click, but nothing else. :headhurt:
Hooked up a charger and it says "charging" .... is the battery just low? (And probably on the way out) or do I need to start to worry abut something else? :blink:
cheers guys...
Wouldnt worry too much, my 2003 JDM did the same, i had the car in my garaged locked for 5 days while i was at Nurburg and come back to a low battery, i should have left it unlocked in the garage as i guessed it was the alarm that drained it.
Cheers guys...
Will leave it for an hour and see how it does. :yawn:
I think a new one is on the cards anyway... read through the receipts and history and not seen a replacement at all, so this one is seven years old. :scare:
VERY weird...
Left her on charge for an hour... came to try again, nothing happened :(
Waited for two mins, checked the volt meter, looked fine, turned on the radio, no problems.
Tried AGAIN... and it worked fine! Started no problem... and stops/starts no problem now. B)
WTF could THAT be? :wacko:
Seems to be charging OK when driving... just popped out in it and it was fine, V's going up as I went.
One thing I DID just spot... one of my dome lights is out.
Suppose I could I have left it on (AGAIN) and it burnt out. Drained the battery enough to not let the car start, but let the ignition come on.
Very strange.
