Advice needed for new quality Speakers
Exotic
Hi guys, I am wanting to change the speakers in my Z but needed some advice. Shall I just upgrade the front speakers only and leave (or even disconnect, although can't I just use the fade function to put just the front speakers) the rears? I do have a sub as per my signature but may actually get rid of the sub in a bid to reduce weight and space, and just go with some high quality front spearkers, anyone done this before. I do listen to a few DVDs so will it be good to leave the rears in there for surround type of effects for DVDs movies etc?
My shortlist is:
Pioneer TS-E170Ci - 17cm Separate 2-Way Speaker System (260W)
•Maximum output power 260 Watt
•Nominal output power 60 Watt
•Impedance 4O
•Frequency response 30 - 33,0000 Hz
•Sensitivity (1W/1m) 88 dB
•Woofer size (cm) 17 cm
•Tweeter size (mm) 28,0 mm
•Network LPF/HPF:-12/-12dB
•Magnets Neodymium magnet
£100
Pioneer TS-A171Ci - Accelerate Series 6.5 inch, 17cm Component Car Speakers 350W
•6.5" (17cm) Component Speakers
•Maximum input power 350 W
•Nominal input power 50 W
•Impedance 4 Ohms
•Frequency response 29 - 29,000 Hz
•Sensitivity (1W/1m) 90 dB
•Woofer size 16 cm
•Woofer material Carbon Graphite IMPP Interlaced Aramid Fiber Cone
•Tweeter size (mm) 20,0 mm
•Cut-out Hole 128 mm
•Mounting Depth 54,3 mm
£90
Focal Polyglass 165VB 16.5cm Component Car Speakers 140W
•2-way 6.5" component speakers
•Polyglass woofer with butyl rubber surround
•TNB Aluminum/Magnesium inverted dome tweeter
•Non-resonant ABS/glass fibre basket
•Outboard crossover with 3-level tweeter control (-3, 0, +3 dB)
•Grilles included
•70 watts RMS power
•140 watts peak
•Frequency response: 60-28,000 Hz
•Sensitivity: 93 dB
•Mounting depth: 65mm (2-9/16")
£128
Noticed that the Pioneers frequency response seem much lower than it's rivals, any views on how good they are?
