craigmdennis Posted May 9, 2011 Share Posted May 9, 2011 I have had my Zed for just over a week now and there is the most annoying clunking noise whenever I go over uneven ground or bumps. It's a 2005 GT4 with the Nismo Kit. Things I have checked: Suspension Front bumper Undertray Break discs / pads Exhaust (The guy I bought it from told me it was this as he'd put a buddy... it is not) No dead body in the boot Sounds like it's coming from the front, low down, but I can't find it. It sounds too heavy to be a loose body panel. It happens whether I am breaking, accelerating or coasting. It is not rhythmic, so not directly engine or wheel related. Any suggestions? I'm at a loss. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 9, 2011 Share Posted May 9, 2011 bananna bar Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 9, 2011 Share Posted May 9, 2011 Drop links potentially, very common issue. Just had mine sorted as it used to knock on uneven ground. All sorted now and silent. Quote Link to comment Share on other sites More sharing options...
craigmdennis Posted May 9, 2011 Author Share Posted May 9, 2011 Drop links potentially, very common issue. Just had mine sorted as it used to knock on uneven ground. All sorted now and silent. I have heard this mentioned before. It's just a case of crossing things off the list I guess. Or take the car apart piece by piece until I find it or the car stops working (as by then it would be just a steering wheel and a seat! lol) Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 10, 2011 Share Posted May 10, 2011 Could be a number of things mate causing your knock, however I would start with checking out the compression arm ball joint and bush. Also have a look at the hub carrier lower ball joint. If you click on my signature picture, you will find all the parts that you may require. Alex. Quote Link to comment Share on other sites More sharing options...
