RisingPower Posted May 8, 2011 Share Posted May 8, 2011 So, had the steering hoses changed at nissan, but now it seems when turning I get wobble through the wheel? (Turned the steering wheel and held on lock a few times for 5 seconds, couldn't see any fluid coming out of near the power steering cooler where it was before) Oh and they apparently greased the rear drop links and now the creaking has turned to a creaking and a clunking sound? Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted May 8, 2011 Share Posted May 8, 2011 So, had the steering hoses changed at nissan, but now it seems when turning I get wobble through the wheel? They probably haven't bled the system properly. Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted May 8, 2011 Share Posted May 8, 2011 Pages from ps.pdf Bleeding process above Quote Link to comment Share on other sites More sharing options...
RisingPower Posted May 8, 2011 Author Share Posted May 8, 2011 They probably haven't bled the system properly. Makes me wonder, just grovelled under the rear and the arb drop links are surprisingly dry for something which would have been sprayed with grease though they did smell of wd40 yesterday? Possible if they sprayed wd40 on it it could make them worse? Sorry, one other thing, would you expect bubbles in the reservoir if there is an air lock? Partner couldn't see any whilst I turned it from full lock to lock... Quote Link to comment Share on other sites More sharing options...
RisingPower Posted May 9, 2011 Author Share Posted May 9, 2011 Thanks lincolnbaggie, thought I was thorough enough the first time I attempted to bleed air out using the procedure, second time it seems to have gone Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted May 9, 2011 Share Posted May 9, 2011 Took me quite a few goes as well - glad it's all sorted Quote Link to comment Share on other sites More sharing options...
