Spacers - Spigot Rings. Pls help!
Daze
Hey guys,
I'm about to buy some hub-centric wheel spacers for my 350z, but have found that the centre bore of the spacer is 67.1mm.
I've come to understand this is larger than the centre bore of the stock Rays 350z wheels (which is 66.1mm).
Is this important to get right? I know you can get Spigot rings to correct this, but I can't find any which are this thin! Only 1mm in it!!
Also, my other car (a drift s13) has aftermarket wheels of 73mm bore, and I don't use spigot rings in that at all - seems fine.
I bought some EBC ones from CS and worked fine. It may be worth pm'ing him but I thought it was just one standard size and not Rays specific
Indeed it is, the 350z center bore (regardless of wheels) is 66.1mm. I've just found some good quality spacers cheap (2nd hand), but they are the incorrect center bore size. Just wondered if that makes much of a difference :)
