Passenger side switch cover
chrisgunton
I need to remove it to wrap it :)
Does the handle have to come off? Can someone shed som light how it comes apart?
I did mine a few weeks ago.
To be clear you remove the aluminium trim gently of the handle do not leaver at the ally trim its is pressed on to the main assembly with a series of plastic lugs running on the edge , inside the handle undo the 2 bolts or screws (I think there 10mm bolts) one at the top, one at the bottom, then lever of the hollow handle from the top and pull gently out and upwards this should now come away.
After that gently lever of the arm rest and the electric switch is held in by some clips that undo.
Just be careful looking for the lugs moulded to the plastic assemplies (handle and arm rest) these are the bits you need to lever at.
