kirk Posted April 19, 2011 Share Posted April 19, 2011 Hi all, I have a 350z on 54 plate. Whenever I start the car the a drive off the hand brake light come on and the engine warning light. After about 10mins the hand brake light goes off but the engine light stays on. No loss of power, noise or other problems. can anyone help me. Thanks I was told you can just push it a code using your pedals.... Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 19, 2011 Share Posted April 19, 2011 may be worth checking your brake fluid level, also after that try a ECU reset. You can find a how to in the Guides section Quote Link to comment Share on other sites More sharing options...
kirk Posted April 19, 2011 Author Share Posted April 19, 2011 thanks for your help i'll give it a try Quote Link to comment Share on other sites More sharing options...
Blacky Posted April 19, 2011 Share Posted April 19, 2011 If your fluid level is low, check your pads Quote Link to comment Share on other sites More sharing options...
kirk Posted April 21, 2011 Author Share Posted April 21, 2011 Took the Z to the doctors on Friday. They put new brakes on and topped up the fluids. cheers for help Quote Link to comment Share on other sites More sharing options...
