ASAP answer needed!
evilscorp
They will fit as already said but will sit in from the arches quite a bit.
Yep, you need more aggressive offsets IMO, you want to be looking at 15's rather than 30's at the least and probably a bit wider too. Bearing in mind a new set arent much more than twice that, perhaps its worth giving Rarerims a call to see if they might be able to help out ;)
