Knocking Noise - Expert Needed!
zacieclay69
Hi all,
I've got a knocking noise coming from the front end when going over uneven road surfaces up to 40 miles an hour :bang:
The drop links and bushes have been changed with no improvement so I wanted to check how best to proceed. My cousin works for Nissan (primarily on GTR's admitidly) but he couldn't find the problem. From looking at past posts it sounds like the next thing to check would be the ball joints in the compression arms as they may be worn - is that correct?
Many thanks,
Zac
Hi Zac and :welcome: to the forum. :thumbs:
The Zed is notorious for suspension knocks and it could be one of many issues.
The most common knock comes from failure of the Compression arm bush.
The Compression arm ball joint and cone seat are also regular failures.
The lower ball joint on the hub carrier is also known to fail.
There are other possibilities however a careful examination should trace the fault.
What ever is giving you the knock, I will have the parts in stock to provide the fix including the lower ball joint on the hub carrier :thumbs:
Here is a taster:
viewtopic.php?f=157&t=43455
viewtopic.php?f=157&t=43456
viewtopic.php?f=157&t=43458
Just drop me a pm if I can help you further :thumbs:
Alex. :)
