Dove32 Posted April 14, 2011 Share Posted April 14, 2011 Hey all, Just a quick question hopefully someone can help me with. I have loud rattling noise coming from my car/engine when the car is idle and the clutch is out, also when the car is accelerating from idle to 2.2k revs then the rattle continues but stops over 2.2k revs. When the car is idle and the clutch is in then there is no noise at all. The car did have a lightweight flywheel added before I bought the car a while back and ive been putting up with it, but its beginning to drive me insane! Before i replace the clutch and flywheel i wanted to make sure it was this and that do that would solve the issue. I understand its no guarentee whatever people suggest, just wanted to know peoples opinion So thanks for any advice anyone can give Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 14, 2011 Share Posted April 14, 2011 By your description it will be the gearbox idler gear rattling away due to you having a single mass lightened flywheel. The fix is simple, fit an OEM Dual Mass Fly and hey presto the noise will be gone. viewtopic.php?f=157&t=31543 Plenty in stock and good to go same/next day Exedy stock clutch kits also in stock. Just drop me a pm if I can help you further. Alex. Quote Link to comment Share on other sites More sharing options...
alibongo Posted April 18, 2011 Share Posted April 18, 2011 Please see my post today 18.04.11, "Corroded Cat Heat Shields". It maybe them same rattle that I have. Quote Link to comment Share on other sites More sharing options...
