TomS Posted August 1, 2011 Share Posted August 1, 2011 Been using mine every week since I bought it. Nice bit of kit for the price! Probably won't clean a patio to a decent level as it's not that powerful but I keep it on a fairly wide setting on the car and a bit narrower on the wheels. You do need an adaptor though as the standard attachment just chucks out a powerful stream of water. Pressure washer + adaptor = £100 I think I paid. Quote Link to comment Share on other sites More sharing options...
cowie Posted August 1, 2011 Share Posted August 1, 2011 Use mine 2-3 times a week for the car,great with snow foam and have done the yard walls and patio which it handled brilliantly, can't recommend it highly enough tbh. Quote Link to comment Share on other sites More sharing options...
coldel Posted August 1, 2011 Share Posted August 1, 2011 Which pressure washer is this? Quote Link to comment Share on other sites More sharing options...
cowie Posted August 2, 2011 Share Posted August 2, 2011 Which pressure washer is this? Nillfisk C110 mate. Quote Link to comment Share on other sites More sharing options...
AK350Z Posted August 2, 2011 Share Posted August 2, 2011 I bought one too, plus the snow foam gun from Tim@Envy. You get two different pressure nozzles, the strong one will take the surface muck off stone and concrete, but obviously not as big an area as a more powerful washer. Good enough for 50 sheets anyway! Quote Link to comment Share on other sites More sharing options...
Norwich Zed Head Posted August 2, 2011 Share Posted August 2, 2011 I would not hesitate to recommend this pressur washer and for £45, its an absolute bargain. I have had mine about 3 months and used the snow foam attachment with some valet pro snowfoam on my car to great effect. Re the questions on the attachments, I would not use the concentrated nozzle on any part of the car, as the wider spraying nozzle is enough concentrated pressure for car cleaning, and even when doing that I would not get too close with it. Personally I rinse mine from distance first of all, then snow foam, leave for 15 minutes, rinse again with pressure washer, wash using 2 bucket method, rinse again, dry, then wax. Great bit of kit. Have also "snow foamed" the conservatory too and that did a suprisingly good job too! Quote Link to comment Share on other sites More sharing options...
geoff-r Posted August 3, 2011 Share Posted August 3, 2011 We bought a Nilfisk a few months back, it recently started playing up and actually overheated the other day took it back to Machine Mart, they've sent it off to Nilfisk now. Maybe just a dodgy one? Don't seem to have much luck with the ol pressure washers! Quote Link to comment Share on other sites More sharing options...
SnailHerder Posted August 3, 2011 Share Posted August 3, 2011 Can this pressure washer - or other washers - be used with an indoors tap attachement like you can with hosepipes? I don't have an outside tap at the moment and would like to get in with the pressure washing action too. Quote Link to comment Share on other sites More sharing options...
TomS Posted August 3, 2011 Share Posted August 3, 2011 Can this pressure washer - or other washers - be used with an indoors tap attachement like you can with hosepipes? I don't have an outside tap at the moment and would like to get in with the pressure washing action too. You use a hose to connect the pressure washer to a water source so just get the correct hose connection for your tap B&Q have loads! Quote Link to comment Share on other sites More sharing options...
SnailHerder Posted August 3, 2011 Share Posted August 3, 2011 Can this pressure washer - or other washers - be used with an indoors tap attachement like you can with hosepipes? I don't have an outside tap at the moment and would like to get in with the pressure washing action too. You use a hose to connect the pressure washer to a water source so just get the correct hose connection for your tap B&Q have loads! Cheers Tom! Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted August 3, 2011 Share Posted August 3, 2011 Used my Nilfisk for the first time last night... Damn thing is faulty, motor went after 2 seconds... Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 13, 2011 Share Posted August 13, 2011 Anybody found these still at £45? Cheapest I can find is £53.12 at Argoose, also the snow foam bottle that you get with this is any good? Or should I stick with my nilfisk snow foam lance? Quote Link to comment Share on other sites More sharing options...
neo-ninja Posted August 14, 2011 Author Share Posted August 14, 2011 go buy a snow foam bottle on ebay they are around £40 with a huge tub of snowfoam. Mine is still going very strong Quote Link to comment Share on other sites More sharing options...
