I O Play (bluetooth)
HassanZ
Hi everybody.
I was just looking at purchasing the Bluetooth I O Play device.
Are these any good? Would they work with my existing Bose stereo and bluetooth module?
I have never heard of these before so don't want to purchase it if it's a waste of time!
When you play music through this device, what is the quality like?
Does any body currently use it in their Zed? Is there a lot of preparation work necessary to get this to work?
I appreciate your help guys and I apologise for the million questions!
Hassan
From what ive seen the ioplay wont work with the bose system but should work fine with the standard radio. It works similar to a Parrot system by using its own amp to bypass your radio and power the speakers itself.
Ah..thank you guys for clarifying this for me :thumbs: Luckily I didn't buy it otherwise I would have wasted my money!
I got excited thinking now I don't have to stick to the 6 CDs that's been in there ever since i bought the car and can listen to music of my iPhone!
So the bluetooth module does not do anything other than store numbers and transmit phone calls to/from a phone.
Many Thanks,
Hassan
Many Thanks,
Hassan
You could do the ipod bose hack though where you solder a 3.5mm audio jack cable to the contacts on the tape deck.. it's relatively easy to do if you have a bit of confidence and some soldering experience.
I recently done it to mine and it works perfectly. I am going to change the lead to a powered ipod plug one soon so that I can play and charge at the same time. Have a search on here as there are loads of threads about the ipod hack.
Here's a pic, you can see the lead plugged into iphone and tucks out of sight when not in use.
