ewan221 Posted April 12, 2011 Share Posted April 12, 2011 Went to put a new rear wiper blade on today, which I thought would be simple but The arm wont lift enough from screen to change the blade, did remove the plastic cover but that didnt help, also took off the nut thinking I would just take off the arm but that was not happening either. Is there something obvious Im missing here ? Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 12, 2011 Share Posted April 12, 2011 You can do it without lifting it up very far mate, an inch is plenty. You can push the little tab/lever where the wiper joins the arm then just slide the wiper down towards the rear of the car. New one will just slide in and click into place. Quote Link to comment Share on other sites More sharing options...
captain Posted April 12, 2011 Share Posted April 12, 2011 Take it off completely and go smooth............ Quote Link to comment Share on other sites More sharing options...
ewan221 Posted April 12, 2011 Author Share Posted April 12, 2011 You can do it without lifting it up very far mate, an inch is plenty. You can push the little tab/lever where the wiper joins the arm then just slide the wiper down towards the rear of the car. New one will just slide in and click into place. sorted thanks for that Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 12, 2011 Share Posted April 12, 2011 Quote Link to comment Share on other sites More sharing options...
iain10101 Posted April 12, 2011 Share Posted April 12, 2011 Could be an expensive alternative but buy a roadster it doesent have one! Quote Link to comment Share on other sites More sharing options...
