david 164 Posted April 11, 2011 Share Posted April 11, 2011 can the speedo be re calibrated in the zed, my digital one is reading bout 4 mph different to the clock,not a big pro blem but just wondering if it can be done,also the rev limiter is reading different,so say if u set it at 4000 it wud flash at 3500 again not that fussed just curious,and hav got a dead spot,as u feather the throttle,car jerks slightly,then clears,any hep wud be appreciated Quote Link to comment Share on other sites More sharing options...
Impressed Posted April 11, 2011 Share Posted April 11, 2011 If you set it at 4000 it will be a constant light at 4000 but will flash before this. Dont know about the speedo mine read 1-2 mph different. I would think the digital one is reading more accurate. My worst bug bear is the average speed. Set the cruise at 70mph on the trip computer and reset average for a couple of mins and the average speed will say 66mph. How can this be? its the same instrument Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted April 11, 2011 Share Posted April 11, 2011 For average speed camera zones, I rely on the GPS Speedo on my Sat Nav. Quote Link to comment Share on other sites More sharing options...
Impressed Posted April 11, 2011 Share Posted April 11, 2011 BTW. If u r postn usin yr fone thn ok. If however you are using a full size keyboard then behave, it makes your post a b1tch to read. I have noticed a flatspot - jerk around 1500rpm if I apply throttle around this speed. However if I apply below this and run through it, its fine. Not that I would normally drive at such low engine speeds. Not noticed any problem with the rest of the rev band, apart from it going balistic above around 5500. Quote Link to comment Share on other sites More sharing options...
