Bc racing coilover fitting questions
trackpig
Hi all
I am going to fit the bc racing coilovers to the car this weekend. Ive been reading the instruction manual which is fairly poor imo. I have a question and I wonder if anyone can advise me?
Front units-
The spring pre load is set at the factory and should not be adjusted (stated in the manual). Only the ride height and damping can be adjusted- fair enough.
Rear units-
The spring platform can be ajusted for height and the length of the damper unit can be lengthened or shortened.
The instructions say i must adjust the damper and the spring platform together if i want to raise or lower the car.
How do I know what damper length to set to suit the height of the spring platform? Getting this wrong will result in bad spring preload or the damper extending too much/ bottoming out!
Any ideas or suggestions welcome :thumbs:
Fitted mine last week and had it aligned today.
I just took it that the rear was factory set also and just counted the number of turns I made to both shock and spring seat.
Hope this helps, I had no knocking issues on the drive home and I know the rear springs had some preload.
Think I need to play with the shock settings as it was a little jumpy on the front end, going to go a bit softer, other than that the ride was very good, seemed to ride average bumps/potholes better than before.
Thanks. I was thinking of taking the same approach.
Not exactly clear though is it?
Cheers.
  • 1 month later...
I got the coilovers fitted and setup. I have lowered the car around 20mm front and back to give what I think is a good compromise for day to day use and a bit of track work.
I have used the car on track now and have to say I really do like the coilovers!
I have experiemented with damper settings and have found 15 clicks all round for road use and 25 clicks all round for track use to be the best.
Recommended :thumbs:
viewtopic.php?f=36&t=49329&p=719493#p719493
