popeacute Posted April 3, 2011 Share Posted April 3, 2011 installed some new ferodo ds2500 on the rears today, but there are some concerns: 1: removed the pads from offside and one of the shims was missing. do i get another one from nissan? (the rectangular one was there) 2: on the other side i was expecting to see 2 shims, one square and one cut at an angle with an arrow on it, but there was 2 rectangluar ones, is this correct? 3: also on the new pads none of them had the metal retainer sticking of the bottom left corner. is this needed? As it was on the pads i removed. thanks Quote Link to comment Share on other sites More sharing options...
popeacute Posted April 4, 2011 Author Share Posted April 4, 2011 right ok i phoned up nissan for shims, £34 plus vat. bit frigging dear for a couple bits of thin metal. so i have found these they look identical to what i need brembo shims and cheap too. http://www.camskill.co.uk/products.php? ... 2313p10459 can anyone confirm these are suitable? Quote Link to comment Share on other sites More sharing options...
popeacute Posted April 4, 2011 Author Share Posted April 4, 2011 3: also on the new pads none of them had the metal retainer sticking of the bottom left corner. is this needed? As it was on the pads i removed. this bit : Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 4, 2011 Share Posted April 4, 2011 the metal retainer is just the wear indicator. When the pad gets low the metal prong will rub on the disc making it scrach. Its not required. Quote Link to comment Share on other sites More sharing options...
D4XNY Posted April 4, 2011 Share Posted April 4, 2011 I just fitted the same pads too but to the front.... didnt bother with the shims, just put plenty of copper grease on the backs and sides And as for the retaining clips, they are just to warn you when brake pads are running low, if you maintain your car often, you can check these yourself. Quote Link to comment Share on other sites More sharing options...
Neilp Posted April 4, 2011 Share Posted April 4, 2011 You have to be careful with copper grease as I found out You just need a very fine coating where it meets the piston and edges of calipers. I have fitted my current bluestuff pads without any as I was directed by http://www.brakes4u.co.uk and surprisingly I've had no squealing etc Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 4, 2011 Share Posted April 4, 2011 alu lube is even better stuff Quote Link to comment Share on other sites More sharing options...
popeacute Posted April 4, 2011 Author Share Posted April 4, 2011 nice one cheers guys.. Quote Link to comment Share on other sites More sharing options...
