SunsetZed Posted April 1, 2011 Share Posted April 1, 2011 Haven't used it since Sunday and went out today and it just won't fire up, it sounds like its turning over but not firing up. Electric locking and cd player are working fine so I'm guesssing it;s not the battery, is it worth trying an ECU reset? I have 3 lights on the dash, the malfunction, oil pressure and battery but from memory I think that's normal? Any thoughts would be hugely appreciated. Update: I tried the ECU reset and when I counted the fast flashes as per the guide I seemed to get a code of ten, ten, ten however that's not a code that I can see on the list? The reset didn't appear to change anything. Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 1, 2011 Author Share Posted April 1, 2011 Anyone? Otherwise it's going to have to be a breakdown call tomorrow, don't trust my local dealer, prefer TGM but they're too far away for the tow people. There is a small independent garage that I trust but I get the feeling this may be too ig a job for them? Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted April 1, 2011 Share Posted April 1, 2011 Hi mate Quote Link to comment Share on other sites More sharing options...
Ian Posted April 1, 2011 Share Posted April 1, 2011 Jump start it. I'd go for battery. Even when mine dies, I can still open it using the fobs, listen to stereo & get dash lights - theres just not enough life left to turn it over Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 1, 2011 Author Share Posted April 1, 2011 I was worried that jump-starting might fry the ECU? Quote Link to comment Share on other sites More sharing options...
Ian Posted April 1, 2011 Share Posted April 1, 2011 No, you can jump start it fine Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 1, 2011 Author Share Posted April 1, 2011 I'll have to ask the neighbours if they have any cables. I'm guessing they need to be fairly high strength ones? Also, and I'm hoping that this isn't required does anyone have any thoughts what else it could be? Quote Link to comment Share on other sites More sharing options...
Ricey Posted April 1, 2011 Share Posted April 1, 2011 Check this bud - make sure you do it right viewtopic.php?f=35&t=43784&hilit=jump+starting Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted April 1, 2011 Share Posted April 1, 2011 the 10-10-10 code refers to 000 and means all is fine Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 2, 2011 Author Share Posted April 2, 2011 Tried the jump leads this morning, decent strength ones and left it running for a good ten minutes but so far nothing, not firing up at all, can smell petrol so I guess the injectors are working? Quote Link to comment Share on other sites More sharing options...
Ricey Posted April 2, 2011 Share Posted April 2, 2011 Do you mean it wouldn't jump at all or you jumped it, turned it off then it wouldn't fire off its own charge? Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 2, 2011 Author Share Posted April 2, 2011 It wouldn't jump at all, after a few minutes it wasn't close, after awhile it sounded better so I'm hoping that it's just that the other car wasn't pwerful enough. I've borrowed a trickle charger and hooked it up in the hope that that will breathe some life into it. If it does turn out the battery is there a guide on how to get the old one out as it doesn't look like the easiest place to get to to remove. Quote Link to comment Share on other sites More sharing options...
Ricey Posted April 2, 2011 Share Posted April 2, 2011 Prob the battery mate - you'll need something fairly meaty to jump it off. Its not a total nightmare getting it off but its not that bad. Couple of bits of trim need to come off. Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 2, 2011 Author Share Posted April 2, 2011 Ok cool, fingers crossed the charger does its job then. If it's just the battery then I'll be happy!!! Quote Link to comment Share on other sites More sharing options...
Ricey Posted April 2, 2011 Share Posted April 2, 2011 Quick word of warning though.........if it is the battery and its gone dead for no good reason then the trickle will prob get it up to spec for starting the car but there's a good chance it'll keep failing. It was a common theme on here last winter - people were finding the battery dead, charging up, all was well then.......2 days later stranded somewhere. And before you ask ....... for a battery Quote Link to comment Share on other sites More sharing options...
SunsetZed Posted April 2, 2011 Author Share Posted April 2, 2011 Update it started after the trickle had done its job but its dark now, touch wood it'll start ok in the morning and then I'll take it out for a decent run and check all is good. If it doesn't then I guess it'll be a new battery. If I do have to replace it then I'll try and create a guide for the site. The least I can do is give a little back after all the help people have offered me, thank you to all of you. Quote Link to comment Share on other sites More sharing options...
