simon da silva Posted March 29, 2011 Share Posted March 29, 2011 Hey Guys. My car keeps on going into Limb mode.. it works fine for 100 miles after i clear the ECU, and then it turns back on. Errorcodes are. P2122 Accelerator Pedal position Sensor P2138 Accelerator Pedal position Sensor Is this a common fault and how can i fix this? this morning i wasen't able to clear the code.. so i had to drive 20miles back home in limb mode ( BORRING ). Is it a new pedal or??? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 29, 2011 Share Posted March 29, 2011 Hey Guys. My car keeps on going into Limb mode.. it works fine for 100 miles after i clear the ECU, and then it turns back on. Errorcodes are. P2122 Accelerator Pedal position Sensor P2138 Accelerator Pedal position Sensor Is this a common fault and how can i fix this? this morning i wasen't able to clear the code.. so i had to drive 20miles back home in limb mode ( BORRING ). Is it a new pedal or??? Simon, try a pedal reset mate Quote Link to comment Share on other sites More sharing options...
simon da silva Posted March 29, 2011 Author Share Posted March 29, 2011 Accelerator Pedal Release Position Learning Operation Procedure 1. Make sure that the accelerator pedal is fully released. 2. Turn ignition switch “ON†and wait at least 2 seconds. 3. Turn ignition switch “OFF†wait at least 10 seconds. 4. Turn ignition switch “ON†and wait at least 2 seconds. 5. Turn ignition switch “OFF†wait at least 10 seconds. ???? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted March 29, 2011 Share Posted March 29, 2011 Seen this a few times normally it is bad contact on the throttle body connections. We tweak the male terminals to make a better contact normally sorts the problem we find. Any more questions ask away Quote Link to comment Share on other sites More sharing options...
simon da silva Posted March 29, 2011 Author Share Posted March 29, 2011 Seen this a few times normally it is bad contact on the throttle body connections. We tweak the male terminals to make a better contact normally sorts the problem we find. Any more questions ask away The trottle bodie sitting in the engine? since the error code is telling me its the senor in the pedal that is defective.. i belive you are right about the bad connection cause my ODB Reader said something about low voltage.. but voltage seems to be fine.. idle is 13v and driving is 13,4-5 ?? should be fine for charging the current batteri installed Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 29, 2011 Share Posted March 29, 2011 I wouldn't assume because the fault code says it is the pedal that it is the pedal.... I had an ABS fault that turned out to be a rear light switch... Also if Mark says he has seen the problem before then chances are he is right... Quote Link to comment Share on other sites More sharing options...
simon da silva Posted March 29, 2011 Author Share Posted March 29, 2011 Ok, i'll check the cabels in the engine bay tomorrow. thank you guys Quote Link to comment Share on other sites More sharing options...
MattRwebB Posted March 20 Share Posted March 20 Did you get to the bottom of this? I’m currently having the same issue on my 350z hr Quote Link to comment Share on other sites More sharing options...
