Firewall holes, where?
evilscorp
Hi guys im trying to mount a front camera to under the bumper, but dont know(cant see) any places where cables go from engine bay to the cabin? and vice versa had a look under the carpets but cant see any rubber grommits or cables? can anyone help? got plenty of cable just need to find a hole! :shrug:
Any people doing Ice installs take the cables through the gromet behind the battery, there is a fuse/junction box there that you will find most of the cables going behind.
+1
Theres also one behind the brake fluid res, that goes through :thumbs:
if you put them through behind the battery they are really easy to access hence most people doing it that way.
You should be able to get in under the passenger footwell without any dismantling but if you need to...
-Take the passenger door sill cover off (looks like a hockey stick), it just unclips if you pull up.
-undo the 2 nuts holding the left hand footwell cover on, one at the front and one on the back wall
-undo the screws holding the cover that has the drink holder (or money tray) in it [cant remember how many there are but just hunt around for them)
that would give you clear access of the area
