Moonhawk Posted March 17, 2011 Share Posted March 17, 2011 I know I have mentioned this in another thread - but need some specific advice. After my clutch problem which is now fixed - I drove the car home last night (<10miles) and as I got home the amber CEL light came on. I rang Nissan today to get some advice and they said to bring the car back down. I queried whether the vehicle was safe to drive with the CEL light on as I dont want to cause damage by driving it, if its the start of something serious - but the guy in the workshop said that if it was serious - the CEL light would be RED indicating that the car is in limp mode. I only did about 100 yards in the car with the CEL light on and was only doing very low speed down my lane - so probably wouldnt have been able to tell from driving the car if it had gone into limp mode. I dont have the manual with me right now so cant check - but googling hasnt returned any information about a red CEL light. Any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 17, 2011 Share Posted March 17, 2011 Safe to drive back to Nissan Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted March 17, 2011 Share Posted March 17, 2011 Id drive carefully until you know exactly what the problem is. With my other halves car the engine warning light was on for about 8 months and didnt cause any problems - in that case id already done a full OBD scan and established that the problem was simply the cat converter on the way out. Quote Link to comment Share on other sites More sharing options...
Moonhawk Posted March 17, 2011 Author Share Posted March 17, 2011 Ok thanks. Its not something I have seen before - and with it coming on after only 10 miles following a major repair, i'm a bit paranoid. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 17, 2011 Share Posted March 17, 2011 I drove mine for a couple of months with various CEL lights on but I had already diagnosed what the problem was and why they were on I expect someone has just not plugged a sensor in properly somewhere If you search on here you will find a guide on how to pull the code from the ecu using the pedals Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted March 17, 2011 Share Posted March 17, 2011 not sure if correct, but I thought if it was a solid light then okay to drive but good idea to pull the code asap to find out what was logged, bit if it is flashing then not to drive at all before checking code? I may well have dreamt that though! Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted March 17, 2011 Share Posted March 17, 2011 You can read the codes and reset the ecu if it's nothing serious. See if it comes back, if it does, further investigation may be needed. Sometimes these flash up, reset and never come back again and even if they do it's usually nothing serious. Procedure can be found in the guides section - viewtopic.php?f=35&t=89 Here is the procedure and error codes. - Manual Method Here is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the "Service Engine Soon" Light. Confirm that accelerator pedal is fully released, turn ignition switch “ON†and wait 3 seconds. Repeat the following two procedures quickly five times within 5 seconds: Fully depress the accelerator pedal (HARD). Fully release the accelerator pedal. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking. Fully release the accelerator pedal (while the CEL is still blinking) **at this point you need to count the CEL light flashes, think it starts by falshes 10 times slowly to indicate it is beginning then faster for the code. For example if it flashes 10 times slowly, 3 times fast, 2 times fast, 5 times fast 10 times slow then the code would be 325, then just match to the code list. Wait about 10 seconds. Fully depress the accelerator pedal and keep it for more than 10 seconds. Fully release the accelerator pedal (The CEL light will continue to blink). Turn ignition switch to “OFF†position and now you can start the car. The CEL light should be gone. - Codes P0000 No Self Diagnostic Failure Indicated P0011 Intake Valve Timing Control P0021 Intake Valve Timing Control P0031 O2 Sensor Heather P0032 O2 Sensor Heather P0037 O2 Sensor Heather P0038 O2 Sensor Heather P0043 O2 Sensor Heather P0044 O2 Sensor Heather P0051 O2 Sensor Heather P0052 O2 Sensor Heather P0057 O2 Sensor Heather P0058 O2 Sensor Heather P0100 MAF (Mass Air Flow) Sensor P0101 MAF Sensor P0102 MAF Sensor P0103 MAF Sensor P0105 Absolute Pressure Sensor P0107 Absolute Pressure Sensor P0108 Absolute Pressure Sensor P0110 IAT (Intake Air Temperature) Sensor P0112 IAT Sensor P0113 IAT Sensor P0115 ECT (Engine Coolant Temperature) Sensor P0117 ECT Sensor P0118 ECT Sensor P0120 TP (Throttle Position) Sensor P0121 TP Sensor P0122 TP Sensor P0123 TP Sensor P0125 ECT Sensor P0127 Intake Air Temperature Sensor P0128 Thermostat Function P0130 Closed Loop, Bank 1 Or Front O2S, Bank 1 P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring P0132 Front O2 Sensor, Bank 1 Rich Shift Monitoring P0133 Front O2 Sensor, Bank 1 Response Monitoring P0134 Front O2 Sensor, Bank 1 High Voltage P0135 Front HO2S Heater, Bank 1 P0136 Rear O2S, Bank 1 P0137 Rear O2S, Bank 1 Minimum Voltage Monitoring P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring P0139 Rear O2S, Bank 1 Response Monitoring P0140 Rear O2S, Bank 1 High Voltage P0141 Rear H02S Heater, Bank 1 P0144 O2 Sensor Heather P0150 Closed Loop, Bank 2 Or Front O2S, Bank 2 P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring P0152 Front O2 Sensor, Bank 2 Rich Shift Monitoring P0153 Front O2 Sensor, Bank 2 Response Monitoring P0154 Front O2 Sensor, Bank 2 High Voltage P0155 Front HO2S Heater, Bank 2 P0156 Rear H02S Sensor, LH Bank P0157 Rear O2S, Bank 2 P0158 Rear O2S, Bank 2 P0159 Rear O2S, Bank 2 P0160 Rear O2S, Bank 2 P0161 Rear H02S Heater, LH Bank Or Bank 2 P0171 Fuel System Lean, Bank 1 P0172 Fuel System Rich, Bank 1 P0174 Fuel System Lean, Bank 2 P0175 Fuel System Rich, Bank 2 P0180 Tank Fuel Temp Sensor P0182 Fuel Tank Temperature Sensor P0183 Fuel Tank Temperature Sensor P0217 Engine Coolant High Temperature Enrichment Protection P0221 Throttle Position Sensor P0222 Throttle Position Sensor P0223 Throttle Position Sensor P0226 Accelerator Pedal Position Sensor P0227 Accelerator Pedal Position Sensor P0228 Accelerator Pedal Position Sensor P0245 Supercharger Bypass Valve Control Solenoid Valve P0300 Random Misfire P0301–*P0308 Misfire, Cylinder No. 1–8 P0325 Knock Sensor, Bank 1 P0327 Knock Sensor P0328 Knock Sensor P0330 Knock Sensor, Bank 2 P0335 CKP (Crank Shaft Position) Sensor P0340 CMP (Cam Shaft Position) Sensor (Phase) P0345 CMP Sensor (Phase) P0350 Ignition Signal P0400 EGR System P0402 EGRC/BPT Valve P0403 EGR Volume Control Valve Circuit P0405 EGR Temperature Sensor P0406 EGR Temperature Sensor P0420 TW (Two-Way) Catalyst System, Bank 1 P0430 TW Catalyst System, Bank 2 P0440 EVAP Small Leak P0441 EVAP Control System Purge Flow Monitor P0442 EVAP Control System P0443 Purge Control/V & S/V P0444 EVAP Canister Purge Volume Control Solenoid Valve P0445 EVAP Canister Purge Volume Control Solenoid Valve P0447 EVAP Canister Vent Control Valve P0450 EVAP Pressure Sensor P0451 EVAP System Pressure Sensor P0452 EVAP System Pressure Sensor P0453 EVAP System Pressure Sensor P0455 EVAP Control System P0456 EVAP Control System P0460 Fuel Level Sensor Unit (Slow) P0461 Fuel Level Sensor Function P0462 Fuel Level Sensor P0463 Fuel Level Sensor P0464 Fuel Level Sensor Circuit P0500 Vehicle Speed Sensor P0505 IACV/AAC Valve P0506 Idle Speed Control System P0507 Idle Speed Control System P0510 Closed TP Sensor P0550 Power Steering Pressure Sensor P0600 A/T Comm Line P0605 ECM/ECU P0650 Malfunction Indicator Lamp P0705 PNP Or Inhibitor Switch P0710 ATF Temp Sensor P0720 VSS A/T P0725 Engine Speed Signal P0731 A/T 1ST Signal P0732 A/T 2ND Signal P0733 A/T 3RD Signal P0734 A/T 4TH Signal Or TCC P0740 TCC SV Solenoid P0744 A/T TCC Signal P0745 Line Pressure S/V P0750 Shift Solenoid/V A P0755 Shift Solenoid/V B P1031 Air/Fuel Ratio Sensor Meter P1032 Air/Fuel Ratio Sensor Meter P1065 ECM Power Supply Heater P1102 Mass Air Flow Sensor Function Heater P1103 MAP Sensor Heater P1104 MAP Sensor Heater P1105 MAP/BARO Switch SOL/V P1108 MAP Sensor Heater P1110 Intake Valve Timing Control, LH Bank P1111 Intake Valve Timing Control Solenoid Valve P1119 Radiator Temperature Sensor Circuit P1120 TP Sensor 2 P1121 Electronic Throttle Control Actuator P1122 Electronic Throttle Control Actuator P1124 Throttle Control Motor Relay P1125 Tandem TP Sensor P1126 Throttle Control Motor Relay P1128 Throttle Control Motor P1130 Swirl Control Valve Control Solenoid Valve P1131 Swirl Control Solenoid Valve P1132 Swirl Control Valve P1135 Intake Valve Timing Control, RH Bank 2 P1136 Intake Valve Timing Control Solenoid Valve P1137 Swirl Control Valve Position Sensor P1138 Swirl Control Valve P1140 Intake Valve Timing Control Position Sensor, LH Bank 1 P1143 Heated O2 Sensor 1 P1144 Heated O2 Sensor 1 P1145 Intake Valve Timing Control Position Sensor, RH Bank 2 P1146 Heated O2 Sensor 2 P1147 Heated O2 Sensor 2 P1148 Closed Loop, Bank 1 P1163 Heated O2 Sensor 1 P1164 Heated O2 Sensor 1 P1165 Swirl Control Valve Control Vacuum Check Switch P1166 Heated O2 Sensor 2 P1167 Heated O2 Sensor 2 P1168 Closed Loop, Bank 2 P1169 Heated O2 Sensor 3 P1170 Heated O2 Sensor 3 P1210 Traction Control Signal Circuit P1211 ABS/TCS Control Unit P1212 ABS/TCS Communication Line P1217 Engine Coolant Temperature P1220 FPCM P1221 Throttle Actuator Circuit P1222 Temperature Sensor Circuit P1223 Throttle Position Sensor 2 P1224 Throttle Position Sensor 2 P1225 Closed Throttle Position Learning P1226 Closed Throttle Position Learning P1227 Accelerator Pedal Position Sensor 2 P1228 Accelerator Pedal Position Sensor 2 P1229 Sensor Power Supply P1271 Air/Fuel Ratio Sensor 1 P1272 Air/Fuel Ratio Sensor 1 P1273 Air/Fuel Ratio Sensor 1 P1274 Air/Fuel Ratio Sensor 1 P1276 Air/Fuel Ratio Sensor 1 P1278 Air/Fuel Ratio Sensor 1 P1279 Air/Fuel Ratio Sensor 1 P1320 Ignition Signal, Primary P1335 CKP Sensor (Ref) P1336 CKP Sensor (POS) Cog P1400 EGRC Solenoid/V P1401 EGR Temp Sensor P1402 EGR System P1440 EVAP Small Leak P1441 VC/V Bypass/V P1443 Canister Control Vacuum Check Switch P1444 Purge Volume Control/V P1445 Purge Volume Control/V P1446 Vent Control Valve P1447 EVAP Purge Flow P1448 Vent Control Valve P1456 EVAP Control System P1464 Fuel Level Sensor Circuit Ground Signal P1480 Fan Control Solenoid Valve Circuit P1490 VC/V Bypass/V P1491 VC Cut/V Bypass/V P1492 Purge Control/V S/V P1493 Purge Control/V & S/V P1564 ASCD Steering Switch P1568 ICC (Intelligent Cruise Control) P1572 ASCD (Automatic Sped Control Device) Brake Switch P1574 ASCD Vehicle Speed Sensor P1605 A/T Diag Comm Line P1610 NATS Malfunction P1611 NATS Malfunction P1612 NATS Malfunction P1613 NATS Malfunction P1614 NATS Malfunction P1615 NATS Malfunction P1705 TP Sensor A/T P1706 PNP Switch P1720 Vehicle Speed Sensor- A/T Output P1760 Overrun Clutch S/V P1775 Torque Converter Clutch Solenoid Valve P1776 Torque Converter Clutch Solenoid Valve P1780 Shift Change Signal P1800 VIAS Control Solenoid Valve P1805 Brake switch P1900 Cooling Fan P2122 Accelerator Pedal Position Sensor P2123 Accelerator Pedal Position Sensor P2127 Accelerator Pedal Position Sensor 2 P2128 Accelerator Pedal Position Sensor 2 P2135 Throttle Position Sensor P2138 Accelerator Pedal Position Sensor Quote Link to comment Share on other sites More sharing options...
Moonhawk Posted March 17, 2011 Author Share Posted March 17, 2011 If you search on here you will find a guide on how to pull the code from the ecu using the pedals Code is 850 (10 slow flashes, 8 fast, 5 fast, 10 fast, 10 slow). Looked it up in the error code table and its not one of the ones listed. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted March 17, 2011 Share Posted March 17, 2011 Code is 850 (10 slow flashes, 8 fast, 5 fast, 10 fast, 10 slow). Looked it up in the error code table and its not one of the ones listed. Blimey that was quick! Mmm might be worth trying again. The first time I tried it it didn't make sense but after a bit of practice Its quite easy. Have another go. Its also possible that it will flash more than one code. which can get confusing when trying to count the flashes. They will be separated by the 10 slow flashes. Quote Link to comment Share on other sites More sharing options...
Moonhawk Posted March 17, 2011 Author Share Posted March 17, 2011 Code is 850 (10 slow flashes, 8 fast, 5 fast, 10 fast, 10 slow). Looked it up in the error code table and its not one of the ones listed. Blimey that was quick! Had already checked it when you posted I checked the code a few times - it always flashes with the sequence I gave above. There only seems to be one code stored. I'll check again later just to make sure I havent miscounted - but i'm pretty sure I didnt. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 17, 2011 Share Posted March 17, 2011 Code is 850 (10 slow flashes, 8 fast, 5 fast, 10 fast, 10 slow). Looked it up in the error code table and its not one of the ones listed. Blimey that was quick! Had already checked it when you posted I checked the code a few times - it always flashes with the sequence I gave above. There only seems to be one code stored. I'll check again later just to make sure I havent miscounted - but i'm pretty sure I didnt. I recorded mine on my iPhone Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted March 17, 2011 Share Posted March 17, 2011 Code is 850 (10 slow flashes, 8 fast, 5 fast, 10 fast, 10 slow). Looked it up in the error code table and its not one of the ones listed. Blimey that was quick! Had already checked it when you posted I checked the code a few times - it always flashes with the sequence I gave above. There only seems to be one code stored. I'll check again later just to make sure I havent miscounted - but i'm pretty sure I didnt. I recorded mine on my iPhone exactly what i resorted to doing Quote Link to comment Share on other sites More sharing options...
ChrisS Posted March 17, 2011 Share Posted March 17, 2011 A quick google http://forums.nicoclub.com/engine-code- ... 96794.html Quote Link to comment Share on other sites More sharing options...
Moonhawk Posted March 17, 2011 Author Share Posted March 17, 2011 A quick googlehttp://forums.nicoclub.com/engine-code- ... 96794.html I did find that when looking around but I didnt realise the OBD codes were universal as that car is an Infinity. I have just found this. http://www.tankota.net/repair/Repair_Ma ... p0705p.pdf If i'm reading this right - the car must have recieved a signal that it was in neutral whilst I was actually driving in gear. If that is right - then its a bit of a relief as it doesnt sound too serious, but i'll still have to get it sorted and reset. Maybe this code can be added to the above list Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 17, 2011 Share Posted March 17, 2011 Hopefully it is something like you said, it is amazing what weird problems can occur I had my ABS lights on and it turned out it was a switch in the rear lights telling the ECU that even though I had my foot on the brake pedal something was wrong as the lights were not coming on So I drove around for a month with no ABS and no TC all because of a £15 switch Quote Link to comment Share on other sites More sharing options...
Moonhawk Posted March 24, 2011 Author Share Posted March 24, 2011 Update. Took the car back to Nissan - apparently they hadnt connected something up right when they put the new clutch in Quote Link to comment Share on other sites More sharing options...
