Replacement for blocked washer jets?
Moonhawk
Does anyone know where I can get replacement wiper arm mounted washer jets from?
My passenger one is blocked. I have traced the tubing all the way to the wiper arm and water is getting to that point - but not getting through the washer jet itself. Looking at the jet - it seems to simply clip onto the wiper arm and so should be easy to replace.
I have done some searching round but cannot seem to find replacement parts.
Perhaps taking the blocked bit and soaking it in warm soapy water and then try pin/air line/bicycle pump/Jedi mindtrick to unblock?
I did think of that - but in trying to get the jet off, one of the clips that holds it in place snapped off (they seem very brittle). If I try and remove it completely I may end up snapping all of them and would like a fall back position if this doesnt work.
If you do try again,warm the plastic up with a hair dryer first. And then hope it's not UV light that made it brittle.
Managed to get the jet partially unblocked. Took multiple blasts with an air pump, multiple twiggles with a pin, a kettle of hot water and about an hour and a half of fiddling. Still one jet blocked - may give it another go this weekend.
