Window Not opening
Ian
Went out in the car tonight and found that my drivers side window has stopped opening, it doesnt drop when the door is opened now either. :rant: Im guessing that it will need the window reset procedure done?? Are both windows controlled by the same fuse?? Had a look through the manual earlier but couldnt find anything about which fuses are which.
I think the window reset is just for when the window doesnt auto drop correctly..your problem sounds like the window motor?? or maybe just a loose connection :)
Went out to the car this morning & the window was working fine :wacko:. Yesterday I left the window down and locked the car, later I went out to the car to get something and set the alarm off (forgot i locked it). Would this have caused an issue with opening the window? I set the alarm off by putting my hand through the window :blush:
